Question about Philips 43PP9202 43" Rear Projection Television
No memory of setup on 43PP925/79
I have to repeatedly reset every setting as they dissapear and revert to the original installation. Even the presets cannot be saved. Is there a battery like on a PC for this or flash ram?
  • 1 more comment
  • grant9999 Sep 11, 2007
    so an eprom is a hardware component that may need replacing? what does "sub menu" mean, is there a sub menu that I can access, or is this the data that the eprom maintains?
    where are the eproms located? I have had a look and can see some fuses that seem OK. As I am slightly capable, could I replace said eproms, given a decent diagram?
  • Anonymous Nov 27, 2007
    I have Philips 43pp925 TV, the problem is after 5 to 10 mints going off fully then wait about 10 to 15 mints and put it on same thing happening, some times srandby LED flashing, sound is also not comming but long time it was like only pls help
  • intouch225 May 25, 2008
    I have a 3-4 yr old Philips 109 cm rear projection TV model 43pp925 There had been a problem with it, as the tv does not come on when you start it up. Intimitently the TV would come on, stay on for a little while and then go off again. Would any one know how to fix it?
    Sergeant:
    Champion:
  • 375 Answers
Eprom problems /sub menu settings/service call should solve it
Posted on Sep 08, 2007
  • g w Sep 12, 2007
    eeproms are located on the main pc board assy and on the convergence board,they must be unsoldered and reprogramed,you may try your sub service menu's if you can get your hands on the settings form a service manual or yoyr local tech.i would try this first.book a service call this is not for untrained people,you can do a lot of damage to your set if not done right.
SOURCE:
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
How do I reset the 52" TV to original settings. Screen is on Widescreen permanently
Could you please post exact model of your sharp tv. however i will give you this generic solution. In order to do this, you'll need to have your remote handy. You cannot reset the television using the control panel.
  • Turn your Sharp television on. Press the "Menu" button on your remote control. Press the "Right" arrow until you see "Setup."
  • 2
    Press the "Down" arrow until you see "Reset" displayed under the Setup menu. Press "Enter."
  • 3
    Type your secret four-digit code using the remote keypad. If you do not know it, you'll need to reset it by following the process in the section "Resetting the Parental Control Password." After you type in the code, "Reset to Factory Preset Values" will appear on the screen.
  • 4
    Press the "Right" arrow to select "Yes" then press "Enter." The screen will show "Now TV Will Restart." Press the "Right" arrow then press "Enter." Wait for the television to reset and revert to the factory default settings.
  • Nov 14, 2010 | Sharp Televison & Video
    I don't have a mannual I want to reset the 10 preset memory station
    You can follow this procedure in doing that, when you are on a station you want to set,. press and hold the enter button while pressing the + or - until you are on the preset # you want, then holding that button until you hear a beep. Repeat for the rest of the presets
    Aug 11, 2010 | Sony Walkman SRF-M70 Radio
    I have an technics ( panasonic) chord organ. MOdel sx-ex5L. I can turn it on, but when I try to set it up for the different modes, it just sounds weird and wont set up. I think it must be one of the...
    Find the "factory reset" procedure and execute it...
    For SOME of the Technics units it is as follows:
    It can be reverted to the original factory preset very easily. Simply press MEM&CTRL button, then select Initial from the LCD menu then followed by Total Organ
    Also there may be a memory battery in the unit that is depleted that needs changing if you find settings are lost when power is removed.
    Aug 08, 2010 | Music
    I NEED TO KNOW HOW TO RESET YAMAHA 5990
    Page 88 in the Manual:
    Under ADVANCED SETUP
    1. Press Master On/Off to set the unit to the standby mode.
    2. Press and hold STRAIGHT / EFECT on the front panel; and then press Master On/Off inward to the ON position to turn on the power to this unit.
    3. Rotate the PROGRAM selector on the front panel to select the parameter you want to adjust.
    The name of the selected parameter appears in the front panel display.
    4. Rotate the PROGRAM selector on the front panel repeatedly to change the setting.
    5. s Master On/Off on the front panel to release it toward the Off position to save the new settigns and set the unit to standby mode.
    THIS is the parameter you want to find in the procedure above:
    "PRESET"
    Use to reset all the parameters of this unit to the initial factory settings with the exception of System Memory and AUTO SETUP settings.
    Choices: CANCEL, RESET
    * Select CANCEL if you do not want to reset the parameters of this unit.
    * Select RESET to reset the parameters of this unit.
    Mar 30, 2010 | Yamaha HTR-5990 Receiver
    Audio keeps reverting to "cinema" mode even after repeatedly trying to set it on "standard" setting.
    try unplugging unit for several hours ( overnight) this is a hard reset, then when its repluged it should revert to standard mode.
    thanks for using fixya
    Nov 25, 2009 | LG 42LC2D 42 in. LCD HDTV
    I lost the owners manual for my Innova - Trifecta Digital AM/FM Clock Radio with Built-In Apple® iPod® Dock Model: VR880SA | SKU: 8955222 and do not know how to reset the preset channels
    I have the manual.
    1. Press the FUNCTION button to select FM or AM mode
    2. Press SKIP to select station.
    3> Press and hold the Memory button to enter channel saving mode.
    4. Press the Memory button to select desire preset channel #.
    5. Press and hold the Memory button again to save into memory. If it has been previously set, the former station is replaced.
    6. Repeat step 2 and 5 to store addtl. stations.
    Any idea as to how to set the volume during alarm mode, it's too loud!!
    Jun 04, 2009 | Audio Players & Recorders
    CR-H100 CD/Tuner/ Amplifier. New about 5 years ago. Tuner won't retain presets. Despite following manual's instructions on both auto and manual tuning, the preferred programme settings are almost always...
    These resceivers have a bulit-in device to retain some electricity to feed backup memory. It can be a battery or a capacitor and I think they have reached their time to be replaced.
    Nov 21, 2008 | Teac Audio Players & Recorders
    On my Technics EX-70 organ, have lost my presets that were originally set up by a professional teacher who is no longer available. I need some detailed help in programming the Voice Setting Computer and...
    To Big Gord. To program voice setting computer, set up a sound you want press & hold white button then button 1 while still holding
    white button. repeat for other setups. before turning organ off always press cancel on VSC should hold settings for next time you use it.
    To set upper organ presets, the sequence is shown on page 17 of the manual.
    To RishiMalla. To reset organ turn on Fullband Setting Computer switch then press black Inital key on bottom key board.
    Feb 28, 2008 | Audio Players & Recorders
    Philips 43PP9202 43" Rear Projection Television Logo
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Steve Allison
    Steve Allison
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
