Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
Tray wont go back in
I cant get the tray to go back in. There is a metal blade that is down in the tray area that I dont seem to remember being there.
  • Anonymous Nov 10, 2007
    I have the same problem with my Impressa Z5.  Unable to get through to customer service.  They keep disconnecting me.  This machine is only 22 months old.
  • nocoffee Dec 14, 2007
    We have the F90 and have exactly the same problem.  Does anybody have a solution?
  • 8 Answers
This is because the machine didn't run the full cyce or the tray was removed while the cycle was not completed. We found that the best way out of this was to re-insert the tray but without the used ground bin. The machine will dump whatever ground coffee directly in the tray but after that you will be able to remove the tray and put back the complete assembly including the used grounds bin.
Posted on Jan 24, 2009
  • Danny Haywood Nov 24, 2011
    This morning I thought I broke my mother in laws coffee maker but after reading your solution all was better thank you very much..
    Danny
This has happened to us with the Z5 also, and we have determined the machine didn't run the full cycle somehow. We get the tray back in by putting the grounds catcher in first, then slipping the tray under it. It's a bit of trouble, but the machine usually resolves the problem on its own. Hope this helps!
Posted on Aug 14, 2008
Exactly the same thing happened to our machine the other day but we sorted it by simply turning off the whole machine and unplugging it. When we turned it on again the problem sorted itself out. Guess you have already tried this but thought I would mention it.......
Posted on May 04, 2008
SOURCE:
True back bar freezing up
Most models have a metal drip collector below the evaporator that has a drain hole in it where the defrosted water goes into before it goes down to the drip trap and then out the drain hose. If the area around the drain hole has cracks, or was punctured during servicing, the drain water can get underneath the tray and run out beside and around the drip tray and never gets into the drain tube and freeze in that location. A careful inspection of this area will reveal any issues.
Aug 15, 2014 | Refrigerators
I cant remember my password so i need to reboot it and i dont know how
Remove cmos battery from main board 3 min will reset all pass words
Jan 18, 2011 | Compaq Evo N610C Notebook
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at grizzly.com helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
Hi my helicopter is 9053 , my helicopter working but dont rise , meanwhile it s charging is full , please help me for how to rise many thanks
if the blades are turning and it wont rise check the top blade turn with you hand and hold the lower gear if it spins its loose the clue inside dont hold the turn blades.
solution: get a small drill bit not to big and a drill at the middle of the shaft by the black part make a hole down to the metal shaft and a littel bit into the shaft know get a small screw that woul fir the hold you just made and in to the shaft and it will hold and wala its fixed
Jun 09, 2010 | xheli 9053 Outdoor Volitation Metal...
Im fitting a 1200 x 800 shower tray but having problems getting old one out same size,its in an en-suite, tray just a bit longer than room, dont want to break tiles thats in cant replace them any ideas
well if the old one wont come out,,, then the new one wont go in,,,as its the same size,,, looks like you will need to risk them tiles to me, even if you cut the old one out, you cant cut the new one back in can you?
so its back to them tiles, go on, risk it!!!
Oct 23, 2009 | Dreamline SHOWER ENCLOSURE TRAY Right...
Cd Player In a Daewoo Nubira 98
its easy rip off the covers and on the side you will see a set of gears, i cant remember what direction but spin them until the tray moves and the steel bars will drop down
Apr 06, 2009 | 1999 Daewoo Nubira
Rear window of 92 Ford Bronco wont go up or down (power windows)
You need to either replace the motor or get a rebuild kit for the head unit. You remove the motor and take out 2 bolts in the head, use a flat blade screwdriver and hammer the pinched areas to get access to the inside gear. its a nylon gear and has 3 nylon runners inside. yours will prob be in pieces that are mixed with thick grease. best to clean all that out. the rebuild kit is pretty cheap or you can just cut a bolt into 3 similar sizes and drop them in the slots. (just remember the slip action the nylon is a safety feature in case you get your head or arm caught in the window as it closes) the metal pieces make it stronger and more dangerous. Put the head back together, pinch the metal tabs, put it all back on. Same solution will work on the door windows as well.
Mar 29, 2009 | 1992 Ford Bronco
360 wont turn on
The disk tray button on the unit is probably being pushed in from the outer cover. When you took it apart and put it together you may have pinched the button in. Very carefully inspect the disk tray button area. The button needs its full range of motion. The faceplate is pushing the button in and that is why it works without it. Or the face plate is making the top cover to press in on the button. Go over the area and watch what the pieces are doing when you assemble the front in regards to the tray button. I had the same problem. Remember these pieces are plastic and after being run (heat) the plastic may want to warp a little since new.
Sep 27, 2008 | Microsoft Xbox 360 Console
Xbox Halo editon
You can try manually ejecting it by using a paper clip and poking it in the small hole underneath the tray.  Keep pressing it and see if you can pull it out.  After that try the eject button again.
Oct 11, 2007 | Microsoft Xbox Console
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
1,008 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
