We have a 4424LD+ phone system and I am using a 4424D+ phone. I bought a headset plantronics vista M12. To use this I have to keep the receiver off hook. Is there a way to program this so you have use for both.
It really does not work well this way. There is not a way to disconnect a call without hearing the dial tone, eventually it will disconnect the call.
I found a button to program on the phone fro headset status but not sure how to program the headset hangup button on the 44424LD+.
Any help,
Barb
SOURCE: Have the 6408D+ phone. Got a Plantronics CS55 Wireless Headset.
You can use an handset lifter accessory, such as the HL1 or HL10 to pick up the handset every time you need to use the headset.
The phone needs a headset hangup and a headset status button. If you have the one, good. But the other needs to be programmed through "central telephone programming" in administration.
If you know how to do that, you just put a headset hangup and a headset status button on the phone.
Once done, headset status will be a toggle button. When on, the button will be lit green. When it is, it basically disables the handset clicker. Then you can use the headset hangup button to disconnect the calls.
