Panasonic CS-S22NKU-1 21,000 BTU Ductless Mini-Split Wall-Mounted Cool Only Air Conditioner Indoor Unit Logo
Anonymous Posted on Aug 22, 2013
Troubleshoot Panasonic mini split ac system - Panasonic CS-S22NKU-1 21,000 BTU Ductless Mini-Split Wall-Mounted Cool Only Air Conditioner Indoor Unit
Brian Mills
Level 3:
Master:
  • Master 613 Answers
  • Posted on Aug 26, 2013
Brian Mills
Master
Level 3:
Master:
Answers
613
Questions
0
Helped
133164
Points
1126
You must list the problem if you want help. You'll never get help with this. Would you take your car to the mechanic and just say "Troubleshoot it" ? He would have to know what your complaint is Richard.
KD Grayson Heating,Air conditioning & Refrigeration
Level 2:
  • Expert 499 Answers
  • Posted on Aug 27, 2013
Expert
Level 2:
Answers
499
Questions
Helped
174074
Points
962
troubleshoot Panasonic mini split ac system - 0fc9940e-d2aa-4b5a-b090-1071c2a75560.pngI have been an HVAC expert since 2008 and these units are very complex, trying to talk a trained technician through the systematic analysis required to accurately identify the issue is difficult at best, trying to do so with an untrained person is dangerous possibly lethal if 1 mistake is made, no exaggeration.
The typical issues with these units are either the condensing unit meaning compressor/fan etc or a communication error which is the harness and circuit board, these repairs are only economically viable under a warranty situation .
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
1helpful
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
My LG 1.5 ton split ac shows F10 error can u pls suggest wht to be done
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Bulance AC Cleaning Repair Services
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
Mini split AC's
they are excellent and very efficient sytems
i have a muti pass ductless in my home and swear by it so much i went to school for them
I am now a mitsubishi cert expert
and cannot sing the praisees high enouhg for the ductless systems
2helpful
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Top Panasonic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
