Question about Audiovox FPE3000 30 in. HD-Ready LCD Television
Audiovox FPE3000 turned off sponataneously and will not turn back on
My AVox FPE3000 30" LCD TV turned off on it's own and will not turn back on. When the power button ispressed (on remote or on the top) the red standby light goes off but the green on light does not light and the unit does not power up. The fans in the PWR supply do not run either. I checked the internal fuse in the power supply and it is good. There is no smell of magic smoke from the TV or power supply and no components appear burned inside PWR sup either. I suspect the power supply is faulty. Any ideas appreciated. j
  • 7 more comments
  • imhal Sep 08, 2007
    Thanks,
    I will attempt to find a schematic. I have been looking for a couple of days and have been unsuccessful. Guess if I can't find one I can just reverse engineer it.
    j
  • sbst1234 Nov 04, 2007
    I am having the same problem with my FPE3000. Did you have any luck repairing it?
    Todd
  • nextel 1 Nov 05, 2007
    I have a similar problem with our 3000. The unit was turned off one evening and will not come back on the next morning. The Green light on the power supply is lit, but neither of the fans in the supply run and the TV will not come on. I have had no luck in finding a replacement power supply from any net search or the company direct, any suggestions?
  • gq7229 Nov 26, 2007
    I have exactly the same problem with FPE3000 .I am trying to find another power adapter but is impossible.
  • imhal Dec 27, 2007
    Hello all,
    I have been unsuccessful in getting a schematic for the unit. I did open the power supply (brick) and found nothing burnt. No evidence of overheating although these are the symptoms. I have found in my case that when the unit will not turn on I unplug the unit from the wall and after a couple of hours when I plug it in it works. This confirms that the problem is in the ps and not in the television itself. Sometimes this works for a few days but the most recent time it has lasted weeks without shutting down. I have been looking for a replacement for the ps but have been skunked on that. I suspect the internal ps parts are used in other power supplies but do not have schematics or any other demo units to compare parts to. If anyone can score a schematic please post and I will take readings/troubleshoot. In the meantime my solution is working for me.
  • wilburforce Feb 20, 2008
    I always suspected the Power Supply (PS) would fail on this TV. The fans often make funny noises.
    Now the thing seems to have failed but not completely, I see the Audiovox logo and then blank.
    Has anyone tried a new PS? Did it work?
  • Power Payless
    Power Payless Feb 29, 2008
    We can help you costomer make the special power supply if you can send us the old power adapter.
    huwb@lcdpayless.com
  • Fixaman Apr 01, 2008
    I Repaired Power Supply (PS) on this TV.
    Now every time when turn on the TV, I see the Audiovox logo for half a second and then black screen(back light goes off)and minute later green indicator light blinks.
  • Anonymous Apr 01, 2014
    is it the power supply which is shorted or the pwr supply regulator
Power supply failure- I found the filter caps were all cooked dry and the yellow glue they use in this power supply turns conductive where it turns dark brown. Unsolder the devices and feet on the heatsinks and remove them along with the stand-up driver board. Change all caps-1000u/16V, 470u/16V, 47u/50V, 10u/50V. Scrape and pick off the brown glue from all devices. Re-assemble. Mine would then fire briefly and I noticed only one fan was turning. Removed the fan and found the bearing was seized in it. Power supply will now run properly with the defect fan unplugged. I won't service one of these again-the picture sucks!
Posted on Feb 16, 2008
All I do is turn on the unit so the red light goes of then I bang the power supply until the fan comes on. The screen comes up shortly after.
Posted on Dec 27, 2007
    Genius:
  • 1,139 Answers
I would suggest getting a schematic of the set and using a multimeter looking at the power supply test points to determine what is happening exactly with the power supply.
Posted on Sep 08, 2007
  • Henry McKelvey
    Henry McKelvey Sep 08, 2007
    I have found by just calling the company and asking for the service documentation and the engineering diagrams they will send the for a fee, but you will have factory approved docs to go from.
No picture.
The problem is with the ic's which will have to be replaced to fix this problem.
Apr 09, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Sound but no picture
The first thing that comes to mind is that the brightness and contrast or turned all the way down. See if you can't turn them up. Otherwise it may be the backlight inverter or backlight itself. Most likely the inverter, sometimes you can tell by looking really close to the screen, if you can still see a faint image then the inverter needs to be replaced. Probably a job for a technician but that depends how comfortable you feel opening up the TV and ordering parts online.
Good Luck!
Feb 27, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Audiovox FPE3000 will not allow Comcast remote operation
Try to find out who really makes Audiovox alot of time a big company like maybe sony or rca or such may make a tv like that and try there codes as well
Mar 28, 2010 | Audiovox FPE3000 30 in. HD-Ready LCD...
NO sound with Dvi/HDmi
Unplug the tv about an hour.Go in the menu reset the sound back to factory setting.Should work, if nothing wrong with ur Tuner signal board.
Feb 14, 2010 | Audiovox FPE3000 30 in. HD-Ready LCD...
Is there a fuse and where on 32 audiovox, no power
Open up the back of the set and follow the power cord feeding the TV, it should be connected to the circuit board which will be the power supply module.
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Dec 06, 2009 | Audiovox FPE3000 30 in. HD-Ready LCD...
Audiovox model FPE3000, has sound and picture but
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Dec 01, 2009 | Audiovox FPE3000 30 in. HD-Ready LCD...
Audiovox LCD FPE3206 problems
Same thing here. Seems like there is an issue with the power supply. There is an interesting buzzing sound coming from the power supply. The power supply is located underneath the rear panel of the set. The panel is relatively easy to remove and it looks like the Power Supply would be pretty simple to replace.
Would like to know where to get a new one. This TV is just over a year old and out of the manufacturers warranty period.
If anyone else has tinkered around with this set and has any other incite to share Id be very interested in hearing it.
Thanks
MacPointMan
Jul 04, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Problem with screen
Mine did the same thing and it was the back light board. Good luck getting one. I had to threaten to sue them and badger Audiovox until they mysteriously had one. Now my power suppy is bad at least I got another year out of it. This TV SUX!
May 27, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Audiovox FPE3000 30 in. HD-Ready LCD Television Logo
655 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
