Apple Mac Pro Desktop Logo
Posted on Apr 09, 2009
Freeze panes doesn't work in mac excel
I place the cursor below the headings I want to freeze, and beside the column I want to freeze. I click Freeze Panes which is available in the Window/Freeze Panes menu.
I scroll my cursor to the right and the left hand column I have frozen disappears - i.e. it has not frozen.
Is there a workaround?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16571
Points
47
HOW TO FREEZE THE TOP ROW OF EXCEL FOR MAC:
Wow - using the above ideas I figured out how to freeze the top row!!! Thanks guys!! Here's how:
1.) Use 'Normal' View (i.e. look up at tool bar, hover over 'View' and make sure 'Normal' is checked)
2.) Select cell B2 (only the cell, not the row or the column)
3.) Click 'Window' (from the tool bar at the top of your screen)
4.) Click 'Freeze Panes'
...et voila! :-)
  • Anonymous Aug 15, 2012
    Thanks! I did it with your help.
Anonymous
Level 1:
  • Posted on May 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16571
Points
46
Here you go - I have looked around and found an osX forum, the solution is though that you have to be in view = normal for freeze panes to work in Mac apps.
click view, select normal. Try freeze panes again.
I still have trouble getting column A (my 'date' column) to freeze tho.
Cheers
adam
  • lena85lin Aug 27, 2010
    Thanks Adam!! Saved me from pulling out my hair completely!
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16670
Points
15
HAHAHA I fixed the problem for MACs to freeze the left column.. You have to select the cell that is to the right and below the column you would like to freeze. So pretend you want to freeze the A column, rows 1 through 35 - then select cell B 36!! Took forever. I still have no clue how to also freeze the top header row as well as the left column, but this works for me ..
  • 1 more comment
  • kecs Dec 14, 2010
    This did not work for me. Any other suggestions?
  • sepidehsabet
    sepidehsabet Sep 04, 2012
    Thank you! It worked for me
  • Anonymous Oct 05, 2012
    Super helpful. Worked for me. What a ridiculous thing to have to do. lol. Could NOT figure out how to freeze the panes I wanted to....****.
How do I Freeze panes in MacBook Air
In Excel on your MacBook Air? If so, try this video tutorial:
How to Freeze Pane in Excel on mac
How to freeze 2 or more rows in excel using mac desk top
click on second row
then chose freeze panes from menu
Cursor is stuck in the middle of the page and will not move to the left side. The back space button or the shift left button do not respond?
You've probably "frozen" your pane. "Freeze Panes" is a feature which allows you to keep one or more left-hand columns or top rows visible while you scroll through your worksheet.
When you ac
You didn't say which version of Excel your're using, but in Excel 2007, you can either freeze the Row 1, Column A, or any number of rows and columns based on which cell is selected (i.e., where your cursor is) when you click on "Freeze Panes."
In Excel 2007*, the way to fix this would be to click on the "View" tab, then the "Freeze Panes" icon, which will give you several choices. Click on "Unfreeze Panes." There you go.
* The steps are similar in other versions.
Cell freeze 3 rows together at a time.
Freeze a Row in Microsoft Excel
Microsoft Excel 2010 can freeze, or lock, a top row as you scroll down the worksheet.
For example, you may need to keep the top row of column titles visible at all times.
The "View" tab on the command ribbon contains the "Freeze Panes" button in the "Window" group.
A single row or a range of rows can lock through the "Freeze Top Row" or "Freeze Panes" options.
Open the Excel worksheet.
Click the top row heading.
The row heading displays a number just left of the first column of cells. The selected row appears shaded.
Click the "View" tab on the command ribbon.
Click the "Freeze Panes" button in the "Window" group.
A list of options appears.
Click the "Freeze Top Row" option.
A black horizontal line appears on the worksheet.
This line indicates the locked row that stays on the screen as you scroll down the worksheet.
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP010342542.aspx?CTT=1
Freeze or lock rows and columns
also
Use Freeze Panes in Excel
Scrolling down to look at a number and then scrolling up to make sure the number you looked at is under the header you expected is not an efficient way to view a spreadsheet.
The Freeze Panes feature of Excel allows you to freeze the labels of your data in place while you review the data.
Follow the instructions in Section 1 to freeze the top row or the left column.
Freeze multiple rows, multiple columns, or rows and columns, by following the instructions in Section 2.Freeze the Top Row or Left Column
Open the Excel spreadsheet.
Navigate to the "View" tab on the top menu.
3 Click on "View," then click on "Freeze Panes." A drop-down menu opens.
Select the "Freeze Top Row" option to freeze the top row.
5
Select the "Freeze Left Column" or "Freeze First Column" option to freeze the left column.
6
Freeze the top row by using the keyboard and sequentially pressing the keys "ALT, W, F, R." Ignore Steps 3 through 7 if using this choice.
7
Freeze the left column using the keyboard by sequentially pressing the keys "ALT, W, F, C." Ignore Steps 3 through 7 if using this choice.
8
Unfreeze panes by repeating Steps 3 through 5 and selecting "Unfreeze Panes" or sequentially press the keys "ALT, W, F, F."
Freeze Rows and Columns, Multiple Rows, Multiple Columns, or Multiple Rows and Columns
9
10
Freeze column(s) and row(s) at the same time by selecting the cell to the right of and below the location you want to freeze.
11
Freeze multiple rows only by selecting the cell in the left (first) column below the rows you want to freeze.
12
Freeze multiple columns only by selecting the cell in the top row to the right of the columns you want to freeze.
13
14
15
Select the "Freeze Panes" option. You have now frozen the columns or rows, or columns and rows you designated.
16
Freeze panes using the keyboard by sequentially pressing the keys, "ALT, W, F, F." Ignore Steps 5 through 8 if using this choice.
17
Unfreeze panes by repeating Steps 5 through 7 and selecting "Unfreeze Panes" or sequentially press the keys, "ALT, W, F, F."
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP001217048.aspx
http://office.microsoft.com/en-us/excel-help/demo-hide-or-unhide-rows-and-columns-HA010241040.aspx
Hide or show rows and columns
If I have a multi-row s/s that has multiple pages, how do I get the row title for columns to appear on each page?
Hi, I believe you're asking about 'freezing panes'...
In Microsoft Excel 2007:
  1. Select the place on the spreadsheet where you want the row titles to appear
  2. Click on the View tab
  3. Click on Freeze Panes button
  4. Select Freeze Panes
Or, you could be asking about defining print rows to appear at the top of each page:
  1. Select the Page Layout tab
  2. Click Print Titles
  3. Enter the Rows to Repeat at Top (e.g., 1:3 for the first 3 rows)
Hope that helps!
How to freeze columns and rows on excel?
To freeze columns and rows in Excel, here's what you need to do:
- Excel 2003 & older: To do this, open your Excel spreadsheet. Select the cell that is below the left-most column heading that you wish to see. Then under the Window menu, select Freeze Panes.
- Excel 2007 & newer: Click on the View tab, and then on Freeze Panes. In here you have 3 options, first one does exactly the same thing as the one from older versions, second one freezes the top row and the last one freezes the first column.
When I freeze a pane (at E6), the dropdown menus in column B no longer work.
HAHAHA I figured out how to freeze the left column successfully on excel for MACS.... So select the cell that is one column to the right and one cell below the column you want to freeze. So if you want to freeze the A column From row 1 - 35, select B36. Get it?? Took me forever, but i figured it out!!! I still have no clue how you could freeze a header row as well, but this is enough for me
5helpful
3answers
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
