Refrigerators Logo
Posted on Apr 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY GE PROFILE BOTTOM FREEZER
THE FRIDGE WILL NOT GET DOWN TO TEMPATURE. THE TEMP IN THE FREEZER IS -1.
  • john_blencow Apr 09, 2009
    No it does not freeze up, it has a thermistor and electronis control.
Jimmy James
Level 2:
Sergeant:
Champion:
  • Expert 260 Answers
  • Posted on Apr 09, 2009
Jimmy James
Expert
Level 2:
Sergeant:
Champion:
Answers
260
Questions
0
Helped
96969
Points
763
Does it freez up? the thermostat could be bad? the compressor fan could be bad. Also try setting the temp. control if not working this may need replacing.
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
My GE Profile side by side fridge freeze the food in the bottom draw. I have set the temp to 43F but keep the fridge at 34 or colder. It frooze the water lines and tank in the fridge several times. What am...
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
3helpful
2answers
Freezer temp on GE profile French door fridge was rising rapidly. I believe I did not shut the freezer door tightly after retrieving something about 9pm. Outside of freezer on sides of fridge was very...
This is by design. It should be warm. This is where the heat exchanger is located to save space.
No worries.... right now it is being over-worked until it reaches operating temp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
1helpful
The freezer keeps getting too warm, it was 30 degrees, came back down to 0, and is now up to 14 degrees.
Could be faulty temp sensors, faulty defrost timer/temp sensor, or failed _condenser_ coil fan (under/in back of the fridge).
2helpful
GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
1helpful
2answers
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
1helpful
2answers
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
