Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
NO WATER TO ICE MAKER
WE HAVE WATER THRU THE INLET HOSE UP TO THE FILTER. THE FILTER FILLS BUT NO WATER GETS TO THE ICE MAKER OR THE ICE DISPENSER/WATER DISPENSER ON THE DOOR.
  • Anonymous Mar 24, 2014
    Is there another control valve just after the water inlet valve? I have disco the plastic line from the water inlet valve and tried to blow compressed air thru the line - it doesn't blow thru. The line is not frozen.
    Problem Solver:
  • 14 Answers
Faulty water inlet valve is the most likely fault
Posted on Sep 14, 2007
Ice maker that fills will water dispensed through refrigerator door.
the valve is probably operated by a celenoid, if you removed it during the hose replacement it may be installed incorrectly, out of line or not have a good ground.
Jul 12, 2015 | LG Refrigerators
How do you flush water thru the water filter of my refrigerator
ice maker does not come out water to water hose and ice maker on/off switch red light two times blinking how can i repair to ice maker?
Jan 21, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker won't make ice
This problem is very common.The ice maker water passing line gets clogged or blocked by ice cube or gets frosted by ice or the water valve,which lets water to ice maker,tray, that valve gets faulty.
The ice maker not working.-------------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker stopped working
Pour about 2/3 cup of water into the icemaker . After freezing , it dumps , replace the dual water inlet valve behind the refrig . If it does not dump the cubes , check that the coils are clean under the refrig at the bottom in front , and if they are and the freezer seems to cool good , then replace the ice maker . NOTE : If the ice maker dumps and not refil with water , replace the valve AND check the tube which fills the ice maker inside , to make sure ice has not frozen inside the tube , which also indicates a bad water valve ( seeps ( not closing completely )) .
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker is not working. Light goes on but no water fills the maker Model LFD25860TT
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX25960ST Stainless Steel French Door...
Kenmore 5483300 side by side. no ice!
your fridge will have a dual water inlet valve, one for water and one to supply water to the ice maker. it could be that the solenoid on the valve that supplies water to the ice maker is not working.
Nov 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Dec 20, 2008 | Frigidaire FRS26R4A Side by Side...
No water getting to water filter or ice maker
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees. also check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. the water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 28, 2008 | Refrigerators
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 25, 2007 | Daewoo FR-064R Refrigerator With Ice Box
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
76 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
