Question about RCA P46920BL 46" Rear Projection Television
No picture or sound
I turned on my tv and it was playing fine and then the picture bowed so i turned it off and it didnt come back on no picture or sound could it be the tube ? and where is the tube in the set and where if needed can can i have it repaired or tube replaced also how much would that cost me. thanks Sepulveda
  • 29 Answers
The most common cause for a bowed picture is the convergence power supply module. The module will fail and sometimes blow the fuse. Average cost of repair would be around $100, if you brought it to a tv shop, more for in home service.
Posted on Sep 08, 2007
Picture goes out - but has sound
i have had this problem on one of my tv s all i did was remove the back of the tv and re-solder all the joints around the tuner (thats where the arieal goes) they go with time because the joints there get so hot . hope this helps
puggy
Jul 07, 2009 | Televison & Video
Digital camera
the camera is working , i did what the guy said with turning to tv and 15 and open battery top , it took 5no times working fine ,thanks very much its amazing and unbeleavable im stuck for words , thanks again regards jamie bow th
Jul 04, 2008 | Canon PowerShot S2 IS Digital Camera
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
42" RCA Projection TV - Sound good, but Picture goes out intermittently.
resolder the vertical output IC . bad solder there can make the CRTs blank for protection and you will lose the picture when the vertical drops out.
Mar 27, 2008 | Televison & Video
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Hitachi 53udx10b
sounds like convergance amp ic's see links below
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Jan 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 61SDX01B picture...
Sounds like the blue convergence circuit still not working.
Assuming both IC's are good, look for open soldered-in pico fuse.
Once bowing problem is solved,then convergence should adjust ok.
Jul 27, 2007 | Hitachi 61SDX01B 61" Rear Projection...
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
91 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
