Question about Dell Photo 964 All-In-One InkJet Printer
Printer will not print with color cartridge in
I changed my color and black ink cartridge, but now my printer does not recognize the color cartridge. The printer will not print with the color cartridge in the slot but will in black and white with the cartridge out..???
  • 1 more comment
  • Anonymous Mar 14, 2008
    I hAVE THE SAME PROBLEM BUT ALL YOUR SUGGESTIONS DON'T WORK. tHE 964 IS A PROBLEM MACHINE.
    tRUDTRATED
  • Anonymous Jul 08, 2008
    I have replace the Reg Color Cartrige with the high capacity color cartrige and the printer doenst recognize cartrige.
  • Anonymous Mar 22, 2014
    printer wont print if one color is out but i want to print in black and white
    Problem Solver:
  • 13 Answers
Go to dell AIO center
click maintain/troubleshoot on the top
under trouble aio problems - click ink levels
click maintenace tabs
and then clean print cartridges and align print cartridges. then try printing a test page.
if this does not work, remove the cartridges and install them again.
let me know how it goes
Posted on Dec 28, 2007
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
I bought a refilled black ink cartridge for my
Replace color cartridge.Printer can't print without color cartridge.In your case the color cartridge is failed.
Nov 24, 2009 | Canon PIXMA iP1600 Printer
Printer not recognizing the new color cartridge
turn back your old color ink -> do cleaning page few times -> replace new one if the problem persist -> change color ink if the problem persist again -> change cartridge
Oct 01, 2009 | Canon PIXMA MX310 All-In-One Printer
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
Dell 922 won't print black ink... only uses color cartridge... I can't find selection to use black ink only. The checkbox for print black n white for color is grayed out... Cartridge levels show black ink...
Perhaps the printer does not recognize that a mono/black cartridge is installed. Remove the mono cartridge and check to see that tape is removed then re-seat firmly. Unplug the printer from wall power to reset. Then try again.
Aug 22, 2009 | Dell 922 All-In-One InkJet Printer
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Printer problems
This will sound stupid, but if you are trying to print a document in B&W with this particular model, you have to force it to print ONLY using the black ink cartridge, if you are out of color ink, otherwise, it will try to use the color cartridge by default. A highlighted word is not recognized as a black image with a colored background, it is recognized as a multi-colored image, s-o-o-o try going into your solutions menu, click on "Change settings" then click on "Printer settings" Then click on "Maintenance" tab, click on the "Ink Cartridge settings" button. From the drop-down menu, select "Black Only". Click on okay. THEN when you go to print the document go to your printer settings and click on the "grayscale printing" checkbox. Then Select "Plain paper" Of course, you have to do this each time you want to print. The MP470 is primarily a photo printer, with text and graphics abilities. It wasn't designed as an all-purpose printer... I found that out the hard way! :-) Unfortunately, this only works (so far as I've seen) if you are out of color ink... it tries to use color by default to 'create' black... I hope this helps out!
Apr 12, 2009 | Canon PIXMA MP470 All-in-One Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Color ink cartridge is defective but black cartridge is okay.
No, you can't print with only one cartridge in the printer. The printer needs both of them to close the electric circuit. Remove the color cartridge and inspect it. Clean the electric contacts on it- sometimes, when the contacts are dirty, the printer cannot recognize the cartridge. If that doesn't do the trick, you will need to replace the color cartridge.
Nov 17, 2008 | HP DeskJet 932c InkJet Printer
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
525 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
