PC Chips M825G Motherboard
Problem for PC Chips M825G Motherboard
How to remove the cpu
By gerardtdi on Sep 08, 2007
There is no lever to lift on the mobo. Is there any kind of lock on the inside of the board? This wood meen I have to remove the board from the case? What a job! Thanks...
Comments:
Sep 12, 2007
- There is no lever to be lifted all aroud the CPU, of course with the heat sink and fan removed! It looks like it is soldered in place!! Tkanks.
Solution #1
posted on Sep 08, 2007
Not Helpful)
mistyman
Rank: Wiz
Rating: 83%, 356 votes
Hi, You will find that the CPU doe's have a lever to remove it. But it is probably hidden under your heatsink and fan. Study the clips holding the h/s & fan down and unclip them.
gently apply a bit of force to the h/s and remove it. You will now see the lever you need
Take as much care as possible removing the H/S and also the CPU other wise you may damage the pins on the CPU.
Regards mistyman
Was this helpful?
Yes
No
Solution #2
posted on Sep 20, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my cpu is very flat but it indicate where to pull. i cannot lift it! help
Popular Solutions for PC Chips M825G Motherboard
Questions and Unsolved Problems for PC Chips M825G Motherboard
Do you recommend PC Chips M825G Motherboard?
Answer
Answer
Win OS 7 does not work with my new ASUS MOBO / MA4A78T-E regarding my Ethernet drivers (I assume)as... (More)
Answer
my mother board is asus p5q pro why theres not support in windows 7 os
Answer
i can't install a cpu heat sync because my mobo does'nt have the white square where you put the cpu... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Chips M825G Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14866
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
