Question about iLO (2 GB) MP3 Player
Memory issue. Whenever I press the power button on my ilo mp3 player i get the ilo logo, then it searches through files and displays the message: "Please leave at least 3MB of memory unused for system usage" There are no songs on the mp3 player, I have formatted it a few times, and when it is plugged into the computer it says it has 1.98GB free space. I don't know what else to try to do
  • Anonymous Jan 02, 2008
    iT TURNS OFF AFTER IT DISPALYS THIS COMMENT
    Genius:
  • 1,153 Answers
Try to find in my computer and open music file and click and drag music to the folder and see if it takes. May have to delete driver and reinstall.
Posted on Sep 09, 2007
SOURCE:
I can download music on my mp3 but when i go to play it it says its empty
Ilo player must be synchronized, coping and pasting files is not enough:
  1. Start Windows Media Player and select following menus: "File.", then choose "Add to Library." then the "Add" button. Then, look for the folder where your keep the mp3s to upload.
  2. Plug the Ilo MP3 player into USB.
  3. Click the "Sync" tab that you find at the top of Windows Media Player . You will find the Ilo MP3 player on the right side of Windows Media Player. If Ilo is not ther, then right-click on Sync tab and click "Refresh Devices."
  4. Click "Library" then "Songs." on Windows Media Player . Highlight the son songs, and choose "Add to Sync List."
  5. Click "Start Sync" button that will appear at the bottom right corner of Windows Media Player. The songs will then be uploaded to the Ilo MP3 player.
Sep 07, 2009 | iLO (2 GB) MP3 Player
Tip
Howdy, Doc; I was wondering if you've got any more help to give an iLO owner. A...
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
on Dec 01, 2008 | iLO (2 GB) MP3 Player
My Mp3 player will turn on but won't do anything
Your player is probably full of music files, take some of them off.
Jul 02, 2009 | iLO (2 GB) MP3 Player
Ilo MP3's screen reading flash error and wont play music
To reset Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
Apr 01, 2009 | iLO MP3 Player
Ilo
Although it should be letting you download more than 424mb of files, there are only 2 things I can suggest:
  1. Try to open up the folder when you plug it into your computer. Search through the folders and see if there are files in there that may not be compatible with your mp3 player and therefore will not display.
  2. Check for duplicate files and that the size of the files is not misleading. I've had a problem where a certain song was displayed as being 2.56mb, I opened it on my computer before it was transfered and it was registered as 60mb because the track would continue to play for hours afterwards because of the file being inappropriately labeled at the ending point.
The fact that there is so much unused and unusable space on the mp3 is unusual, but you may have a problem also with your formatting. You DO have to leave some space in your mp3 player to leave room for the operation files of the mp3, so although it is labeled as having 2gb of space, you have to save at least a couple mb of space to let the system function. Hope this helps.
Jun 12, 2008 | iLO (2 GB) MP3 Player
Flashing ilo problem
plug it into your computer and then take it out
Jan 20, 2008 | iLO (2 GB) MP3 Player
Zen v plus
Press and hold the Play button while powering on your player.
When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Jan 17, 2008 | Creative Labs Zen Micro MP3 Player
ILO wont work
One of two things..try a new battery...or it's possible that your button lock button is in the lock position ( look under the power button make sure it is pushed up)
Dec 24, 2007 | iLO (2 GB) MP3 Player
ILO MP3-New problem just ocurred..... Turning the unit on the display logo just blinks off and on.
The company no longer supports the player, so the firmware upgrade is no longer available
Jun 13, 2007 | iLO (2 GB) MP3 Player
Ilo logo, search, sort, repeat
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 05, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
63 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
