Question about Casio Exilim EX-Z750 Digital Camera
Speck on lcd screen
Howdy- There's a speck appearing on the lcd screen. I zoom in, it comes slightly more into focus, then drifts right offscreen if I zoom to maximum. Does this mean it's on the sensor? I suppose I shouldn't risk opening it up? I've had the camera for over a year and am pretty sure I'm past any warranty - any suggestions on where to go in the New York area (or where to send it off to) for a fair repair price? Thanks!
  • untangledup Jan 03, 2009
    I have this same issue but mine looks like a hair that is magnified ... I'm wondering if lint gets inside through the telescoping lens apparatus...
    Champion:
  • 217 Answers
Dirty lens, you need professional fix.
Posted on Sep 08, 2007
SOURCE:
Black speck in images
Take a look at "The Low-Pass Filter" subsection of the "Caring for the Camera" section of the manual (page 105 in my copy). If you need a manual, you may download a copy here.
Mar 19, 2012 | Nikon D40 Digital Camera with G-II 18-55mm...
Why are my pictures blurry when focus is all the way out, and focused when all the way zoomed in? this is also visually obvious on the lCD screen. zoomed out( out of focus)..zoomed in( in focus).
your camera's lense is clear? try clean it with suitable cleaner for lense. If still not working, check your user manual for setting
May 09, 2011 | Cameras
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
Focus is blurred yet lense works in /out
check and see the min and max distance for focus in the manual. also slight movement can cause this also.
Oct 16, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Internal dust speck on Canon A720is in same upper right corner
If dust is in the camera, it must be opened. I suggest not doing this yourself. Lookup a Canon dealer in your region and ask for support.
Jul 22, 2009 | Canon PowerShot A720 IS Digital Camera
Camera wont focus or stay on
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
May 25, 2009 | Olympus FE-340 Digital Camera
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
Poping sound, white specks and what looks like sparks
Possible arcing CRT or possible arcing IHVT part # 239111.
Dec 29, 2006 | Proscan PS50700 50" Rear Projection...
Manually focus the C-5500 Sport Zoom
Occasionally it is necessary to have the ability to manually focus a digital camera. A good example is shooting through the windows of a tour bus on a rainy day. The camera may choose to focus on the raindrops on the window rather than the actual subject. To enable the MANUAL FOCUS function hold down the OK/MENU button for a second or longer. In the lower left corner of the LCD screen you will see MF (MANUAL FOCUS) and AF (AUTOFOCUS) with AF highlighted in green. Use the left arrow key to select MF. You will now be able to use the up and down arrow keys to manually focus the camera. An added feature of the C-5500 is that when you are using the MANUAL FOCUS Mode you will see a magnified portion of the image in the center of the LCD screen. To get out of MANUAL FOCUS Mode, simply use the right arrow key to reset the camera to AF. Then press the OK/MENU button to return to the default functions.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Casio Exilim EX-Z750 Digital Camera Logo
65 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
