Hi Judy,
According to Pride's troubleshooting documents the service indicator
(wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here:
http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdfFLASH CODESCode #1- Flash Code: One, pause, one
- Cause: Possible Stall Timeout
- Possible Solution: Turn joystick off, then on.
Code #2- Flash Code: Two, pause, two
- Cause: Battery Fault
- Possible Solution: Charge batteries, check battery connections and fuses.
Code #3- Flash Code:Three, pause, three
- Cause: Left Motor Fault
- Possible Solution: Make sure the left motor is plugged in.
Code #4- Flash Code: Four, pause, four
- Cause: Right Motor Fault
- Possible Solution: Make sure the right motor is plugged in.
Code #5- Flash Code: Five, pause, five
- Cause: Left Park Brake Fault
- Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6- Flash Code: Six, pause, six
- Cause: Right Park Brake Fault
- Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7- Flash Code: Seven, pause, seven
- Cause: Joystick Fault
- Possible Solution: Check the joystick connection.
Code #8- Flash Code: Eight, pause, eight
- Cause: Power Module Fault
- Possible Solution: Check connections to the power module and batteries.
Code #9- Flash Code: Nine, pause, nine 9
- Cause: Controller Communication Fault
- Possible Solution: Check bus connections from the joystick to the power module.
Code #10- Flash Code: Ten, pause, ten
- Cause: Controller Fault
- Possible Solution: Contact Technical Service for assistance.
Code #11- Flash Code: Eleven, pause, eleven
- Cause: Incompatible Device Fault
