Question about Cyberhome CH-DVD 300 DVD Player
Changed settings As previously posted, accidently changed settings and now there is nothing. Tried solutions in owners manual but still nothing. Anything else I should try?
  • 4 more comments
  • ms brennan Sep 08, 2007
    Problem is with CyberHome CH-DVD 300 DVD player
  • ms brennan Sep 09, 2007
    Holding stop button for 30 seconds did not restore factory settings. I can hear the disc loading, but the screen remains black.
    Thank you Qrocker!!! Holding the stop button on the DVD player (not the remote) caused the power light to cycle off and on, resetting to factory specs. I'm back in business.
  • paulhowell Dec 16, 2007
    can't get "last memory" off and I'm stuck in French....HELP!!!!!!
  • Anonymous Dec 20, 2007
    Player was trying to load - with no results. I changed settings and shut it down. Now I can't get it to turn back on. What to do? Tried holding the stop button in for 30 seconds - no results.
  • minebine Jan 02, 2008
    Yes, I have the same problem and the stop butten proceedure is not working. Is there another way to reset to factory settings or to switch to another video mode?
My Cyberhome CH-DVD 300 was worked fine for two years on the YpbPr setting on my Vizio 26 ' inch tv. Last night we swapped out one of the kids CD's and popped in our adult CD thing. I tried resetting with the stop button per the manual and per several comments on this web site, to no avail.
I cannot get anything on the set up screen and it acts as if nothing is going out to the TV set. .
Open to any suggestions,thanks
Posted on Dec 27, 2007
Just a sincere thank you to ms brennan for his "hold the stop button to reset" tip. It worked beautifully and kept a Cyberhome 300 out of the circular file.
F. Grant (we all need a little help sometimes)
Posted on Dec 21, 2007
GREAT TIP ... the stop button reset worked for me!
Posted on Sep 09, 2007
Press and hold the Stop button on the DVD player itself it should reset back to factory settings
SOURCE:
Easy Flo SQ9020 stopped working - what should I check to identify what the problem is?
I am assuming you have checked the breaker that it is on? Have you tried using it at a different outlet?
Jan 10, 2015 | Easy Flo Vacuums
Canon pixma mp287
Are you sure the correct printer is selected in Excel? I would compare Excel print settings with Word settings, since Word is printing docs.
Dec 08, 2013 | Office Equipment & Supplies
GE camera Z4300
POSSIBLE SOLUTION..
I just bought this camera for my daughter and after first inital picture after setting up camera, it also wouldnt snap a pix. It auto focused fine but wouldnt snap the pix.
I tried calling the GE digital camera support line but kept saying office was closed..and there is no online support for this particular model. The C1433 shares the same owners manual if you do a web search. I think Z4300 was meant for sale in UK because most reviews are UK based.
So after I gave up trying to contact GE , tried changing different settings, replacing battery, etc... finally I just RESET the phone to default settings and WHELLA... it worked. At least for now anyway.
Maybe there was a setting somewhere that was turned on accidently. Personally, I think the Menus and Submenus are a bit confusing.
So ...since I believe others are probably going to run across this issue, I thought I would share my experience.
Jul 10, 2013 | GE Cameras
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I bought a used car with the original car stereo in it. it displays loc on the screen of the sterio but i dont have the unlock code, is there an override code that i could use so i can reset the code for...
Yes. As long as any previous owners havent changed the factory set code, you can call a dealer and give them the vin# and they can give you the code. If a previous owner changed it then look in the owners manual because usually the owners manual tells you to record the new code in the back under "notes" or new radio code. Check there first or follow the change codes procedure in the manual and try to follow the steps they might have been told to and see if they did it. If not call the dealer and get the code from them and hope no-one has changed it.
Good luck! Scott
Please rate my solution if you could - Thank you!
Sep 04, 2011 | 2000 Buick Park Avenue
I traded my old phone for a razor and everytime I turn on the razor it says to enter an unlock code. I've tried 1234 and 0000.
It maybe is a code set by the previous owner. You have to ask him or if all else fails, try restoring to factory settings.
Mar 06, 2011 | Motorola Mobility RAZR V3
Monitor Language stuck on Japanese
The manufacturers website has the manuals and most of the time you can download them As for as the language goes. You may have changed the Regional settings by accident. Click on Start>Control Panel>Regional and Language settings. Set it back to English.
Dec 26, 2008 | Sys Technology SYS 172L-C-JT 17" Flat...
I cant change the language
I have Olympus Camedia c-700 ultra zoom camera. somebody changed its language setting accidently and now i could not figure out hou to change back to english.
Jan 09, 2008 | Olympus Camedia C-700 Ultra Zoom Digital...
Cyberhome CH-DVD 300 DVD Player Logo
219 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
