What you need to do is open the lid of the printer and the cartridge will roll to the middle and you'll see the ink cartridges and all you have to do is pull out the desired ink cartridge that you want to replace and put in the new one. If you have any other questions please let me know.
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple...
(More)
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple of days ago. Test pages print fine from the print controller.
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has...
(More)
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has never been used for scanning
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink....
(More)
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink. How can I select "print in black only?"
