After one bad virus took over I had to clear out the whole system.Now I will restore with back up disk but the disk is not working (nothing works) what can I do to get my factory specs back with out bying a new computer.
what is the right way to clear the whole computer and start new from scatch. Thanks Arno
Beat me to it pontelemon.....lol.
Just as the Guru said and mine is...see below.
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process.
Step 3 can also be Done without the created CD or DVD whichever media you backed it up from, i.e I just read from another Acer User Manual that the Laptop has the image on a hidden partition as does my Toshiba and I never used the DVD I created using their S'Ware to make my Recovery Discs, instead I booted into the Recovery (Norton Ghost) Program provided on the Laptop by following Toshibas Instructions, usually holding down a Key while powering up the Laptop...........I assume Acer uses a similar method.
Your documentation should mention it if not it will be on Acer's website, under AcerSupport, Downloads, etc.
Good Luck
Try this:
Restore your unit back to factory default
1. Boot up on the ACER screen, hold down ALT and tap F10.
2. Select "Restore system to factory default".
3. Enter your Empowering Technology password: 000000
it is a acer 8204WLMi,I took out windoas xp pro.,the disc came with the computer,after I installt everything from the factory I made a back up disc with the disc providet by the factory and burnd it.
it never shows the restore system,it don't let me in to recovery system,I need some other way to get to the computers recovery.
What the Brand/Model ?
What exactly did you clear already? Programs? OS?
What is the "backup disk" you have? What software was used to make that disk?
When you power the computer up, do you get the text-based Power-On System Test on your display?
What operating system are you using?
