Question about ViewSonic VX2235wm LCD Monitor
When i leave my PC for about ten minutes and come back the screen is black. if i power off/power on it comes back to normal for a mili second and then goes black again. During that mili second it says "analog" in the top right corner of the screen. To fix it i have to unplug cables from monitor and PC and plug back in. tried switching to different resolutions with no luck. monitor is 3 weeks old. please help.
  • 1 more comment
  • Anonymous May 02, 2008
    same problem as above, any help?
  • bigus90 Aug 11, 2008
    Powers up fine, then screen will go to black after about 5 seconds. Pressing power button on monitor producers same - on fro 5 seconds then to black. 6 months old. Tried changing DVI cords - same result.
  • kathycory Aug 19, 2008
    My monitor turns to black from time to time. It will be fine for a month and then start acting up. If I power it off then on the screen comes back, but after a few seconds or minutes it goes black again!
  • 3 Answers
Hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
Posted on Sep 10, 2008
Hi, I have a ViewSonic VX2235mw LCD Monitor it was working fine then all of a sudden the screen turned off and now it wont turn back on. The power light is on and is Blue but no sign of life in the screen...
This is a very common problem with this model after a few years of use. This problem is caused by a failure of the capacitors in the power supply board hat powers up the back lights in the monitor. When the back lights don't power up you get no display on the screen. Here is a link to a repair guide for that model that shows how to open the unit and what to look for and replace to repair the monitor.
Here is part one of the three part video repair guide posted at the above link:
Jan 29, 2013 | ViewSonic VX2235wm LCD Monitor
No power to vx2235wm. How can I fix it?
Black screens or no pictures are usually caused by a failure in the back light power supply. Many times the monitor is working but with the back lights not turning on you can't see the display. Here is a link to a repair guide that will show you how to open the unit and what to look for and replace to rebuild the power supply and bring the unit back to life.
I hope this helps, if so please rate my solution.
Dec 07, 2011 | ViewSonic VX2235WM Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
My ViewSonic VX2235wm will come on for about 3 seconds and then go off (black screen). Power remains on according to the front LED (amber LED), but you have to turn the monitor back on (purple LED) to get...
Look for bad caps as shown in my pictures here:
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Capacitors kit:
Jul 27, 2010 | ViewSonic VX2235wm LCD Monitor
Viewsonic monitor -- VX2235wm LCD
avintagedish, Possible problem w/unit power supply. Go trade it in on new a new wide screen so the electronics technician in the repair area of the store can (with a little luck) put less than $10 in parts into your unit and maybe have a nice VX2235WM to give to his 10 year old kid to play games on. I sure hope you have a valid warranty!! You should verify that VX2235WM does same at KNOWN GOOD pc!!! Swap-in a KNOWN GOOD monitor to prove pc is OK!!! Read my FIXYA profile and learn "flashlight test" for "rude an crude" test of "switch-mode-power-supply" status. Follow the links you find there to other web sites for more info. Check to see if ViewSonic has a cash+old swapout for factory refurbished unit for premature failed units! I'm lmistyrel over on aim. and 12fixlouie on FIXYA good luck in your quest to fix unit. It can be fixed. Just do your research FIRST! So you don't get ROOKED if you contract out the work. Read, read, and read some more!! Visit YOUTUBE for video clips of LCD monitor repair and disassembly. FYI.
Bye for now.
Feb 05, 2010 | ViewSonic VX2235WM Monitor
Black screen
Look in the power/inverter board for bad caps with bulging top first, post back what you see inside so we can you further, see failed VIEWSOINC due to bad caps:
Feb 02, 2010 | ViewSonic VX2235WM Monitor
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm monitor looses power ...
I've not seen this problem on a ViewSonic but have on a Dell flat screen. The fix was the obvious one: the power connection on the back of the monitor was loose -- have you checked this. Also if the power cord is too tight it could be the problem. Other then this, it sounds like a short inside the monitor.
Hope this helps
Mar 17, 2009 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
273 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
