Motherboards
Problem for Motherboards
Generic problem for all Motherboards
BIOS intermittently loses CDROM
By ryd_pastor on Sep 08, 2007
I have an OEM PC with a BIOS ID of 03/15/2005-601-686A-6A6LIB09C-00. If the PC reboots in XP, it intermittently loses the CDROM in the bios. The PC randomly reboots when using Internet Explorer 6, or the mouse will stop working (hangs). I replaced the bios and reinstalled XP Home, but the problem still remains. What is my problem?
Best Solution
posted on Sep 08, 2007
Helpful)
mistyman
Rank: Wiz
Rating: 83%, 356 votes
Hi, first check that your RAM chips are seated firmly, then check the CPU fan for dust, then if you still have the problem try disconnecting the on/off switch wires that run from the case to the board, bridge the two pin out to mstart the computer and see if problem still exists.
The final test I can offer is the power supply,
If you can use a multimeter and test the voltage. Yellow =12v red=5v black=ground.
If you get a variance of more than 2v replace the unit. Another way is to try a diferent power supply.
Regards mistyman
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 22, 2008
Not Rated)
fuad_iron
Rank: Apprentice
Rating: 0%, 0 votes
i have tecra 8100 on the monitor write "ready for Bios Update..bios update from disket from driver
press any key after finish" what this problem???????
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
how do i unlock channels on an ntl set top box?
Answer
dell rev.aoo aa a85538-702 cant power up need terminal diagram
Answer
CANT,TRACE POWER INPUTS ON BOARD REVAOO
Answer
i am using asus k8v-mx mother board, and im just finished reformmating my system using windows 7.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motherboards:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
