Question about Sharp Aquos LC-15E1U 15 in. LCD EDTV
Black rectangle appears on screen
A black rectange appears on screen
  • Anonymous Oct 10, 2008
    Thanks! Definitely worked!
  • Anonymous Feb 19, 2009
    Worked on mine too.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Check the settings for the CC (closed captioning) on your menu. Make sure it is turned off - if it is set to TEXT mode you will get a black box in the middle of the screen. Also look for a button on your remote labeled "CC"
Posted on Sep 08, 2007
Problem solved. Thank you, the CC had been inadvertently turned on. It was very simple.
Posted on Oct 08, 2008
It worked
Posted on Dec 31, 2007
It worked
I just changed the closed caption. It was on T2. So far, so good.
Thank you so very much. I was about to panic.
JC
Posted on Nov 04, 2007
SOURCE:
A black rectangle appears in my screen and it doesn't go away
The closed caption function is ON with your TV now. Make it OFF.
Jul 29, 2012 | RCA TruFlat 27F520T 27" TV
I get a black rectangle in the middle of the screen. I can click any button (mute, view mode, cc) and the black rectangle will go away and whole picture will appear, for a couple of seconds and then the...
I do know that on Zenith CRT televisions of the 1990's this will happen and all I did to fix it is to go to the menu and turn the text feature off. This may be true with your Sharp as well.
May 21, 2011 | Sharp Aquos LC-32D40U Television
Black Box in the lower portion of the screen will not disappear
Check your Closed Captioning settings in the menu. I would bet money you have the "Text" feature enabled. Change it to OFF and you should be all set. I hope this was of some assistance.
Mar 25, 2010 | JVC AV-32120 32" TV
Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Jun 03, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Black rectangle appears on screen while trying to watch movie
This happens all the time, on your remote, go into the Menu and disable Closed Captions. It will go away after that.
May 01, 2009 | Sony DVP-NS575P DVD Player
Black Rectangle Box appears shortly after turning on TV
That is the PIP (picture in picture) setting, on the TV's remote control. locate the button marked PIP and press the button, it should clear the little box.
Apr 04, 2017 | TruTech PVS31170S1W 17 in. LCD Television
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Trouble viewing DVDs
I signed up for the "chat" and the problem was solved very quickly. Thank you - great service!
Oct 07, 2008 | Televison & Video
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Black rectangle on screen
Usually that is a part of the closed caption settings. If it is set to either T1 or T2 that box will appear ....
Dec 17, 2007 | Televison & Video
Sharp Aquos LC-15E1U 15 in. LCD EDTV Logo
861 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
