Question about kawasaki PVS-10921 Portable DVD Player
Will not play dvds
Dvd spins but the "eye" will not slid up or down. Therefore the dvd will not play.
    Genius:
  • 1,003 Answers
YOU MAY HAVE A BAD OR DIRTY LASER LENS TRY CLEANING LASER LENS WITH CANNED AIR THEN TRY IF THIS DOESNT WORK YOU PROBABLY HAVE A BAD LASER LENS especially if it isnt lighting up red
Posted on Jan 15, 2008
My protable DVD player(philip) is unable to play korean / Hong kong DVD series only and after dropped on the floor. I try so to play the dry cleaner and also the same problem as mentioned...
A dvd writer (dont matter what make) is using a concentrated beam, called the eye, that is actually lies on a balanced spring, if you can call it that, and when you put in a dvd that eye is lifting up close to the dvd/cd to start read, first it read the lead in and then the lead out and if happy it plays what ever is on that disc, and when you drop the dvd writer that springs get damaged and the eye don't lift up high enough to read the dvd, while it is still reading other dvds it again depends on the type of make (pay close attention on the thickness of some dvds, it is build in layers and that is the possible cause)
Dec 11, 2010 | Televison & Video
Will only play about half the dvds that we put into it. once in awhile if you turn it off and on it will read the disc.
This sounds like the spindle is not spinning the media you may need a new motor, take the top off to see if when you press play the dvd spins this will confirm this
Dec 21, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
My laptop dvd is not playing its always saying no disc when i try to play any disc
Clean the eye with a cotton swab and a little alcohol.Swirl it around on the eye lightly in both directions.Let it dry then repeat.Be sure to do this very gently.Also clean the chrome rails on each side the same way, where the eye slides up and down.Then try inserting a dvd at least a couple of times to give it a chance to read.Also its not too unusual to have some bad dvds even if they are new.Look in device manager and make sure the drive is showing and that the region is set to 1 in the drives properties as well.Chances are the eye is dirty though if its not reading well.
Oct 08, 2009 | Computers & Internet
NEW DVD DRIVE AS MINE DOES NOT WANT TO PLAY NO DVDS NO MORE, IT SPINS THEN STOPS THAN SPINS THEN STOPS THEN SAYS NO DICS!!! CLEANED MAGID EYE BUT STILL DONT WORK
run ur pc in safe mode and insert dvd disc and then use this around 2min and then start ur window normally and ur dvd drive working
May 07, 2009 | Philips LX3900SA System
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
I place dvd in and after loading it saids please eject the disc playback feature may not be available on this disc. i tried one of my dvd's, and it did the same thing.
well, maybe by having the player un-plugged overnight i will see a difference tomorrow, but for now i had to buy an upgrade DVD player, the laser eye cleaners only clean small scratches in the eye and the main problem from that is when all of the dvds played either skip or freeze, in this case the dvd will not spin or load the disc menu, good luck!
May 06, 2008 | Philips Magnavox MWD200G DVD Player
CD Player problem
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded;
5. relube, clean as necessary
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 10, 2008 | Audio Players & Recorders
EMERSON DVD PLAYER CLICKING NOISE..DISC ERROR MESSAGE..HELP!!!
Had a similar problem. Called for support, but was told needed new reader. I took off the cover and manually slid the reader mechanism back and forth a few times. After doing this, tried another dvd and it worked. Apparently it was stuck and not able to move to read the dvd. Give this a try.
Jul 24, 2006 | Emerson EWD2203 DVD Player/VCR
kawasaki PVS-10921 Portable DVD Player Logo
48 people viewed this question
Top kawasaki Televison & Video Experts
wayne chamberlain
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
