Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP always in sleep mode.
When I turn on the monitor i see the UltrSharp logo for a very short time like half a sec, after that a black screen, the problem appeared gradually, first the monitor was having troubles waking up from stand-by mode, after a couple of days it went totally in stand by mode even i cant see the "no signal" warning when not connected to anyting. the power is ok (tried it on a different PC) and the rest of cables are good, tried also the RGB/SVideo and the sane issue. Any idea?
  • 1 more comment
  • Anonymous Nov 02, 2007
  • sh2337 Nov 26, 2007
    I have two dell 2001FP monitors hooked up to 5200 video card, one analog port, one digital port - everthing working fine until this morning.
    The monitor on the dvi port does not display anythng now, and the computer does not recognize the monitor is there any longer.
    The monitor itself reports it's in power save mode and to move mouse or press keyboard to wake it up.
    Can't figure out how to wake it up!
  • Anonymous Mar 03, 2008
    I am getting the exact same problem as the last guest
    Genius:
  • 1,153 Answers
I have a dell ultrasharp and at first it would not come on at all. Open it up and found loose connection on plug connectors 3 pin. Soldered and would come up but blinks in and out sometimes take longer than other times. Big Capacitor when open up Power supply was leaky. Check for bad caps
Posted on Sep 08, 2007
Dell Inspiron One 19 Black screen after dell logo boot up
Sounds like you have a video driver issue. See if you can boot from your "Dell Resource" CD or any other bootable CD disk. Power on the computer and tap the F12 key to get to the "Boot Selection Menu". Insert the "Resource CD" into the CD-ROM drive. Select "Boot from CD/DVD drive" from the selection menu. If the computer boots from the CD drive then you Operating System Software is the problem.
Mar 19, 2013 | Dell Inspiron One 19 All-in-One Desktop PC...
Dell UltraSharp 2001FP (Gray) 20.1" LCD Monitor
Most likely, this is failing "inverter."
The backlight of the monitor (that makes the image visible) is controller by a special chunk of electronics called an inverter. They tend to fail over time. The symptom is that the backlight either never comes on, flickers, or shuts off after a short period of time.
It is a moderately advanced repair job to change out the inverter, but you can usually get the part on eBay. Search for the exact monitor model number and "inverter".
The 2001FP has six lamps and the inverter is fairly expensive. You might be better off putting that money towards a newer monitor.
Apr 11, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor won't wake up after going to sleep for about 1/2 hour. orange light is burning. if I turn off power switch, it's still orange when I turn it on again. The computer is still on (in sleep mode I...
It sounds like the power management drivers with your OS are responsible. Maybe you should disable the power management on your computer, or possibly upgrade them and/or the BIOS.
May 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
The light is always yellow and the monitor wont turn on
Yellow led light means the monitor is in 'sleep' mode. There is no signal being sent from whatever it's connected to. If it's a computer, try checking the connection(s), make sure it's not come lose inside the computer, try if you can the computer on a different monitor or the monitor on a different computer.
Nov 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Monitor 2001FP Blank Screen
From your description your backlight is going out. The fluorescent light when it begins to burn out tries to draw too much power. Your inverter is sensing this 'too much' power draw and shuts down power to the back light. Replacing the backlight is the most technically difficult repair of an LCD, and most repair shops don't even offer this service. I recommend that you sell your LCD 'AS IS' on eBay or a similar website. The Power board and the Control Board are both usable parts that can be easily salvaged from most Dell Ultrasharp monitors.
Oct 05, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP Monitor Problem
I have seen many of these. It appears the video processor board is dying or dead. You can replace the board or the monitor.
http://www.lcdrepair.us/2001fp-logic.html
This is the board. Not to hard to replace if you have some tech ability.
Dell 2001FP
You rmonitor is likely fine, and the culprit is most probably your PC, specifically the graphics card. We won't rule out the monitor, however, until learning the specifics regarding your equipment - PC, graphics card, motherboard, and so forth, please.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 14, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
2001FP LCD Half Display
please refer to this link for help..
http://support.dell.com/support/edocs/monitors/2001fp/EN/trouble.htm
Sep 09, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001fp - Ramdom horz strips
Just had the same issue with the horizontal lines. In my case, too, turning off the monitor would make it go away for a while. called Dell, turned out it was still under warranty (3 years), got a replacement monitor the next day. Way to go Dell!
Dec 05, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
536 people viewed this question
Alun Cox
