Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Frigidare Front Load Washer dispenser drawer wont drain.
Herrdoktor on Sep 08, 2007
Frigidare Gallery model# 417.39022891
After running a load through the machine and we go to start the next we have to pull the dispenser drawer completely out and dump out the remaining water and fabric softner. I know that some water is normal but most of the time the fabric softner section is FULL of water and softner mix. I have cleaned the drawer and all the holes in the drawer. Sometimes it will work but most times it won't. I normally do my own repairs but can't figure this one out. There is a electric mechanical device with an arm that directs the water flow to the different sections. Could this be the problem part? Washer works perfectly other than this. It's about 5 years old.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 08, 2007
Very Helpful)
Krazytech
Rank: Guru  Frigidaire ExpertFrigidaire Expert
Rating: 91%, 544 votes
I think you have something stuck in the fill hose.. Remove the top two or three screws in the back.. then pull out the hose that goes to the tub. I bet you will have something in there.. most common is the inside liner to a bleach cap..let me knowif this it it... krazytech
Was this helpful?
Yes
No
Related Problems
E10 error code. I have to keep hitting the start button so...
hello! when i wash a load of laundry (admittedly, I am new...
how do you take out the bellow in the frigidare washing...
I have the same problem as the poster that posted the post...
Hi, My washer ( GLTF2940ES3 ) has an issue of switching ON...
Can you Help with these Washing Machine problems?
Spring came loose from bellows on...
Solve
My Frigidaire washer just lost the spring in the back part of the bellows. Model Number GLTF2940ES1.... (More)
my washing machine gets to the spin...
Solve
my washing machine gets to the spin cycle and will not drain. the message reads f03
EFO error code
Solve
what does EFO code mean on our washing machine?
the drum seems to be loosening from...
Solve
I can get the drum to clunk by simply lifting it from the front or rolling it over slowly. It... (More)
washer wont fast spin
Solve
washes fine when goes to final drain rinse fine but wont spin. please help
Sponsored Links
Describe your Washer problem:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Washing Machine Experts
Top Washers & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
