Question about Digital Audio Rocbox MP3 Player
Help with my mp4
Everytime i want to listen to music i end up getting a " disk error" sign> please help
  • Anonymous Mar 27, 2008
    I receive a 'disk error' when trying to listen to music. There is no mention of this in the owners manual so I don't know how to resolve it.
My mp4 won't say charge how can I solve this problem
Posted on Dec 29, 2007
I have no hold button so i cant listen to it what do i do
Posted on Dec 20, 2007
SOURCE:
My MP3/MP4 Player keeps saying "disk error"
sounds like a corrupt memory chip or if it has a hard drive it has a bad sector maybe formatting it might help
Mar 24, 2010 | Audio Players & Recorders
When I go to listen to my mp4, it says "No songs available for playback. Please connect to complaint software or device and transfer songs". It will no longer sync with my computer and I cannot listen to...
I started to have the same problem today and was also getting a "Library Error Encountered...." message. I was able to resolve it by Formatting my player. I lost all my data and settings but now I can put music on it again. To format your player go to the Home menu-Settings-Common Settings-Format
Nov 19, 2009 | Sony Walkman NWZ-A826 Digital Media Player
MP4 disk error!!
FORMAT your player in Windows to see if that helps resolve the problem. Either a problem with the memory or a possible memory hack. Take a look here: http://mympx.org/forum/support-how/35010-how-removing-memory-hack.html.
Hope that helps.
Jun 27, 2009 | Dane-Elec Music One MP3 Player
MP3/Mp4
Dear All
My ACTIONS HS MP4 USB Flash Disk has a lean screen. i switched on for the first time and the top edge slant from left to right. checked the Menu Options but no luck. i know you can scare up a normal monitor screen but dont know how to sort this one out.
thanks for any help
bret
Feb 24, 2009 | Lasonic MP3 Player
CANT GO TO MUSIC SAYS DISK ERROR
my system cannot detect my apex mp3 player of 1gb capecity
Feb 16, 2009 | Delstar DS-802 Digital Media Player
DISK ERROR WHEN I TRY TO USE MP3
Double check p. 17 of the manual for a firmware upgrade, in case this message is caused by a db corruption, but the error may also be caused if your player is in the "lock" or "hold" position.
Link to the only manual on Centon's low-budget website:
http://www.centon.com/documents/mp3guide.pdf
-Tha Mp3 Doctor
May 28, 2008 | Centon Electronics MP4-001 MP3 Player
Craig mp4 cmp615d troubleshooting
my craig mp4 player just shows a hour glass like everybody else. i have read the solutions but never receive the answers from them. now how to get the hour glass to go away?.....and if so how to reset the device if frozen. thankz for the support when i receive my answer.
Dec 15, 2007 | Audio Players & Recorders
Manual for infitek mp3/mp4
Problem: Infitek MP4 player is recognized by Vista and Windows XP but when you try to put files on it, error pops up.
Solution: The MP4 needs to be reformatted to FAT32 file system, here is howto do it:
1) Connect USB cable to PC
2) Connect Infitek to cable.
3) An AutoPlay window will pop up on your PC. Select "Open folders to view files using Windows Explorer"
4) On the left of the explorer window the following will be seen "Removable Disk (?:)" (? can be any letter in the alphabet, most likely E-K)
5) Right click on "Removable Disk (?:)" with your mouse and select "Format"
6) "Format Removable Disk (?:)" window will appear, select FAT32 from the FIle system Combo box and select Quick Format from the Format options and click on START
You may need to format the MP4 more than once, it did not work for mr the first time.
7) After you receive a message, Format completed successfully you can drag and drop any files to the "Removable Disk (?:)" which is the MP4 player storage area.
8) Disconnect the cable, turn on the MP4, if at main menu use the >>| key to get to the Music, Click MENU key to get to the first song, click >|| to play song.
I used .WMA files (Windows Media Player) songs. They seemed to work ok
Oct 07, 2007 | Coby MP-610 MP3 Player
Disk Error Message
the best thing to do is RE format the disc. i am currently having the same problem , witch i am tired of fixing them. if the item is from ebay : hong kong , i suggest you tell the buyer and complain. people will do anything for good feedback. saw formatting it will work. but you'll have the same problem in the future. either you copy all your music files to a folder. or buy one from Argos , woolworths etc etc...
Aug 30, 2007 | H&B MP401 MP3 Player
Digital Audio Rocbox MP3 Player Logo
89 people viewed this question
Top Digital Audio Audio Players & Recorders Experts
Ibrahim Makki
Level 1 Expert
ray gallant
ray gallant
Tom Chichester
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
