I have 2 bxi hifonics 1606d mono amp and 2 brutus atlas sub 12' and i want to know how to connect one sub to one amp each can someone please help me send me a diagram
Wire the subs at 2 ohm each. red to red and black to black and then to the amp. if thay are a dual 4 ohm sub. dual 2 ohms will need to be wired red to black on one coil and the other conected to the amp.
On some models a separate extension tube gets installed through a knockout on the back panel. The extension tube fits into the part where the condensate drips into the pan; the opposite end has threads for a hose. This tube (if applicable to your model) should have been in the box with the unit. There isn't any information on the brand or model you have. Looking at the instructions for your model should also provide an answer. If you no longer have the instructions, turn the unit on and try to locate where the condensate drips into the pan. The hose would have to connect from there.
Possibly, but I doubt it. Because, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.. 1. Operator Error - The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a mechanical unit, set the manual control knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the Unit, before removing to inspect & clean it, if necessary. If washed, allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to where the air
temperature at floor level is colder than at shoulder level in basement applications. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
Not all of the above will apply to your situation. But, they are good know for future reference. I hope this helped you and thanks for choosing FixYa.
Dorothy, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.
I hope this will help you further troubleshoot and solve the problem. Thanks for choosing FixYa.
It's not difficult to do, so I have included a link to the Owners Manual for your mode. You will need to use Internet Explorer as your web browser to view it and print it.
Apparently, someone in customer service was try to blow you off, with answer that is not even reasonable.
There are 5 basic reasons for what you have described. Not all may apply to yo, but they are worth knowing for future reference. Number 1 is the most prevalent and overlooked.
temperature at floor level is colder than at shoulder level in basement application. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
As I mentioned before, not all of the above may pertain to your application, but it's worth knowing for future reference and for the moment one or two of the things listed may help you now. If you continue to have problem with the unit, advise Frigidaire, that you would like to enter a warranty claim for repairs. Believe me, they will go out of their way to help you then.
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
temperature at floor level is colder than at shoulder level in basement applications . Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
can happen.
I hope this helps you to troubleshoot & solve the problem. Please let me know. Thanks.
Fandymay, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If your unit is manually controlled, turn the humidity extraction know to Maximum.
temperature at floor level is colder than at shoulder level. in basement applications Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
can happen.
Hope this helps you to troubleshot & solve the problem.
John, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
If
can happen.
John, I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Nika, There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If your unit has a manual control, rather than an LED Screen. Turn the Manual knob to Maximum. 2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the Unit, before removing to inspect & clean it, if necessary. If washed, allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
If
can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Pull out the water collection tray. You will see a small pipe (about 1/2" diameter) in the top of the area where the tray came from. This is the "drain" that fills the tray. Connect a hose to this pipe and run the hose to a floor drain if you have one. I used a section from an old garden hose for my unit. There also may be a small opening in the back wall of the dehumidifier to route the hose more aesthetically.
are the atlas subs dual 4 ohm voicecoil??
