Televison & Video Logo
Posted on Apr 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound but no picture
Working fine then in a span of maybe 30 seconds rainbow colored dashes popped on the screen for a couple seconds then went away. Next was some static and a loud pop like a fuse blew. The picture was instantly gone but the sound is find. Worth repair and if so what is a ballpark cost?
TONY BIGNELL
Level 2:
  • Expert 147 Answers
  • Posted on Apr 09, 2009
TONY BIGNELL
Expert
Level 2:
Answers
147
Questions
Helped
43111
Points
326
Almost certainly the convergence IC's are shorted. Big job; perhaps $300 to $400.
Screen went black but sound stayed
Your Xbox Rims In Xbox ARE NOT WORKING.
tip
Screen with Rainbow Colors [CRT based TVs]
This fault appears on picture tube based televisions are due to low EHT [Extra High Tension} voltage from the LOT [Line Output Transformer] or [Fly back Transformer]. There are mainly two cusses for this.  The first one is with the high voltage rectifying diodes.  These diodes are within the LOT itself, and will be sealed; and no replacement can be done. If the fault is with these diodes/diode; there is no other way than replacing the LOT as a unit.
The second possibility is with the free wheeling capacitors.  Replace the capacitors connected to the collector of the horizontal output transistor to negative ground point.  There will be a capacitor with high voltage ratings.  Replace the yolk return capacitor too.  If these do not help, replace the Line Output Transformer.
The third possibility is with its picture tube connector socket.  This socket can be located at the CRT base card. This is a common fault  seen with most of the CRT TVs.  If this socket have fault, the set will take more time to display picture.  Usually 15 to 30 minutes.
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
Half of screen is fine the other half the color is like a rainbow
you can use a demagnitizer to correct the color of you tv.that is available at electronic supply store..keep you tv away from magnetic area such as speaker of your sound system.etc
2helpful
2answers
Have a Vizio P42HDe purchased in 2005. Right half of screen is fine. Left half is series of small vertical bars (various colors). Sometimes they go away and all of screen is okay. Any ideas?
I bought mine in Jan 2005 and today it did the exact same thing....doesn't go away. Seems like a 5 yr. lifespan on these.
Will try a Panny for Christmas !!
mikebc580
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
2answers
Rainbow vertical lines going up and down the screen, no picture
thanks no further assistance needed from you--ta ta.
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
2answers
Color rainbow in picture
Your problem sounds like someone got a magnet too close to the CRT. This can be removed with a degauss coil (which you probably do not have) or it will eventually go away if your built in degauss circuit is working. Everytime you turn on the set the circuit degausses the crt so colors can be displayed properly. If the circuit is not working you will need to have a tech repair it.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
