This is a used machine bought on ebay. Problem has been ongoing but got worse this week. It reads occasional disc first time. Often I must reload multiple times to read. Sometimes opens without reading. There is a whirring sound, but not steady. Sometimes it gets jerky with playback when I can get it to read. Once it starts to read it seems to work O.K. until next time I use it. Tried blowing compressed air to clean dust. Reset all settings to factory default (it worked for a day).
Well compressed air is ok to a certain extent. But sounds like you need one on one with laser. Open up and clean with soft cloth and alcohol, I found the best way to do it. let dry and try again. Hope this helps
denon 9000 has problems reading dvd discs. Plays fine for an hour or so then skips....
(More)
denon 9000 has problems reading dvd discs. Plays fine for an hour or so then skips. changing discs does not help. Must let system cool down and start over
after heating up the dvd skips and eventually will lock up. if I let it cool down for a few...
(More)
after heating up the dvd skips and eventually will lock up. if I let it cool down for a few hours, I can play a dvd again for a while
Can you please help me. I have a dvd player edison dvd-9000s model and accidentaly change the setup...
(More)
Can you please help me. I have a dvd player edison dvd-9000s model and accidentaly change the setup display to HD from the player.Now when i put a movie dvd only sound no picture from the screen and message High Definition Mode. I try to press the setup from the remote, no effect and still the message is High Definition Mode.How can i return to the menu to change the setup and watch movie..Please help me retchel_parial@yahoo.com thanks Retchel
I have a Denon DVD-9000 player that doesn't always read the
disk. Sometimes it locks up, skips, or...
(More)
disk. Sometimes it locks up, skips, or says the disk is not
readable. It doesn't matter what the age of the disk is. It won't
read the newest one, but will read some copies. A cleaner was used, then
the machine was opened to check for dirt, etc. I sent the unit in for
repair and a new optical sensor was installed. Less than two months later it
started doing the same thing, and another optical sensor was installed (under
the 90 day service warranty). Less than three months later it is now doing the
same thing. We don't use this DVD player that much, either.
There is something very defective in this high-end player, and I would really
appreciate finding a lasting solution.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
