Back to:
Tags:
DVD Players
Generic problem for all DVD Players
Dvd recorder goodmans door sticking (by 5 users)
posted by ericam on Sep 07, 2007
my dvd recorder perfect working order except a door sticking problem constantly wont open upon which of course i am unable to place any discs,give it a knock it opens however dont want to continue doing this,how do i fix this.
Comment by ericam, posted on Sep 08, 2007
thankyou the dvd is relatively new however does sound has if its something to do with this belt changing it could poss solve it.thankyou.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on Sep 27, 2008
have liteon 5005 dvd recorder, about 3 year old, over past months, when you press open it sticks, numerous attempts and then it works, what is the answer
Comment by aeinc10, posted on Dec 12, 2007
I have Lite-on 5005A DVD RECORDER and the dvd cover does not open. One time I pried it open and it will open and close right away and I could not use it. When I pried it open I cleaned the surfaces of tray with silicone used for lubricating treadmill belt.
On the cover it says do not open. However I am going to open the cover and see if belt is loose or scratched and try to fix.
Sharad Ambekar
Ph: 1-248-642-9472
Comment by ashbuk, posted on Nov 14, 2007
just put in dvd tonight and it won't play. went to open it and door won't open. just makes a noise when i press open and close but won't come open. felt like prying the $&%*^( thing open.
Comment by Guest, posted on Nov 12, 2007
My door sticks when the cover is on when the cover is of (sometimes) I press to close tray then by itself it opens again. If I hold it shut utill the disk engages it will play (sometimes)
Best Solution
Helpful (85)
jkas
Rank:Guide Guide
Rating: 80%, 8 votes
open up your machine then check the cd tray there is a motor that drives the tray. between the motor there are gears which rolls the tray in and out. check properly you will see a belt '' blader kind of'' plz replace with brand new one it will work fresh coz if the belt is worn out then it means motor can not pull the gears to enable opening and clossing of your cd tray
Rating Locked! (?) ericam has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dvd recorder goodmans door sticking:
I don't want to Accept this solution
Solution #2
posted on Apr 09, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
mayby belt dressing might work
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these DVD Players problems?
DVD Players
How do I stop a VCR recording?
DVD Players
watching a programe and recoding another on my dvdr
DVD Players
Memory card does not produce pictures when installed in...
DVD Players
rec
DVD Players
lost my instructions for my DVD. need code+instructions to...
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
