Hobart 40 in. AM14-254 Free-standing Dishwasher
Problem for Hobart 40 in. AM14-254 Free-standing Dishwasher
The water temperature does not get over 98 degrees.
By nbestgen on Apr 09, 2009
First the dishwasher shut it self off. I don't know if it was in reaction to an automatic shutoff it has to protect itself or what actually happened. After turning it back on the water temperature stayed at about 115. Today the water temperature will only get to 95-100 degrees. I was wondering if it could possibly be the heating element or what else could cause this. If you have any advice I would appreciate it. I know it is an AM14.
Comments:
Apr 12, 2009
- I am going to clean out the inside of the machine today. I had someone tell me that the magnetic float may have some buildup on it that needs to be cleaned off. I don't know if this is what is causing the water to not heat up or not. The water is still at only 100-110. If you have any suggestions let me know. Thanks.
Solution #1
posted on Apr 12, 2009
Not Rated)
bigg t
Rank: Guru
Rating: 86%, 609 votes
Did you solve your problem?I'm a hobart tech and repair these often.Let me know.
Comments:
Apr 12, 2009
- The float is the first to check,if it still doesnt heat look to the bottom right of the machine,you will see a gray plastic box.Turn off the circuit breaker,open the box you will see a black round disk (the hi limit) press the button if it clicks it should start heating.
Was this helpful?
Yes
No
Popular Solutions for Hobart 40 in. AM14-254
Questions and Unsolved Problems for Hobart 40 in. AM14-254
Do you recommend Hobart 40 in. AM14-254 Free-standing Dishwasher?
Answer
Answer
a portable dishwasher doesn't hook up to sink
Answer
Dishwasher wil not run. The "Control Lock" light is on and will not go out by pressing... (More)
Answer
unable to select cycle. when power is turned on sounds like it is trying to run.
Answer
I have a broken motor of the timer control. where can i buy one? Kenmore dishwasher... (More)
Answer
model SM6A.D serial. 90.013.931 i need the hot final rinse pump for this. thank you
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Sedona, AZ
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
