Computers & Internet Logo
Posted on Apr 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to access web address
Hi I've tried to connect with my running club's web address but goggle sates 'Oops This link appears broken'
Another club member can still access the web address
www.eastantrimharriers.org.uk
Bilal Kabeer Butt
Level 2:
  • Expert 59 Answers
  • Posted on May 16, 2009
Bilal Kabeer Butt
Expert
Level 2:
Answers
59
Questions
Helped
16854
Points
102
If you are using google chrome! then try cleaning the cache first! if it does not works enter the url in the address bar then while it is opening the site press stop button or the "Esc" key on the keyboard and then press "Ctrl+F5", you can also try this on Internet explorer and fire fox. hope that solves your problem! there is no problem with the site the site is online...
Lara Douglis
Level 3:
  • Computers & ... Master 229 Answers
  • Posted on Sep 25, 2019
Lara Douglis
Level 3:
Answers
229
Questions
0
Helped
240879
Points
1375
Chrome privacy issue is one of the most common problem for nowdays. it can be due to the several reasons. visit askprob community to fix the problem.
https://www.askprob.com/forums/topic/quick-steps-to-fix-your-connection-is-not-private-google-chrome/
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
212
Points
Suggestions for navigation error are enabled by default. To access this feature, follow these steps:
  1. Click the Tools menu Unable to access web address - chrome_toolsmenu.gif.
  2. Select Options.
  3. Click the Under the Hood tab and find the 'Privacy' section.
  4. Select (or deselect) the 'Show suggestions for navigation errors' checkbox.
  5. Click Close.
Oops this link appears to be broken
This means that the site is terribly busy. if you try three or four times you will get to it. Or try after sometime.
3helpful
Oops this link appears to be broken dns error - cannot find server windows 7 explorer 8
The error refers to the Domain Name Server (DNS) that your system uses is unable to translate the Uniform Resource Locator (URL, web address either Typed in the address line or linked using a hyper-link, favorite or default home page) (In english, the translation of a web address link www.google.com to the Internet Protocol (IP) address that computers actually use to show the page)
Possible causes:
  1. The URL is wrong. (Typed wrong, link no longer active, link changed)
  2. The DNS server listed for your ISP configuration is not working.
  3. The web site is offline.
  4. The DNS server settings for your internet configuration are wrong.
Possible resolutions:
  1. Try a different Web Address, see if it works
  2. Restart (Completely power off your Cable/DSL modem and then do the same with your router)
  3. Check you IP address configuration settings and ensure that auto-assign DNS is selected (Default setting)
  4. Boot to safe mode with networking, see if you can get online that way.
4helpful
"oops the link appears to be broken"...while accessing facebook.
This is common problem. Make sure you type the web address correctly.Most of the times it happens because of invalid link typed in the address bar.
Also try to check your internet connection.Empty cache and browsing data. Hope this time you will be able to open facebook.
1helpful
Oops! This link appears to be broken. i can't sing
You might be using low bandwith (mostly dial up connection) for your net browsing. Try using higher bandwith connection.
This error means that the URL/Address is wrong.
Check for spaces, URLs should not contain blank space.
Cannot access 192.168.0.1 to create a DMZ keep getting a oops!link appears to bhe broken on any ip address i try to enter on the address browser
go to command prompt and type in telnet 192.168.0.1 if it doesnt go through just reset the router and it will go through,since the router might have been assigned a different ip address. Make sure that you are using windows xp
At lease half of the times I try to access my yahoo emali address
make sure you dealte all of your cookies. on top of your browers window you will see tools go to internet options and dealte the browser history.
May 30, 2009 • Yahoo Mail
Nokia 7610, Web unable to process
CHECK YOUR CONNECTION SETTINGS ,THAT CHANGE YOUR CURRENT ACCESS POINT TO SET US DEFULT
Jan 05, 2009 • Nokia 7610
2answers
DI-524 connection
Hi jyothikry firest u configure your madam go to web page and access your ip address 192.168.1.1 then go to in said configure your madam
2answers
Unable to make connection with www.omaha.com
So you can access any site, but you cant access www.omaha.com?
Grand Canyon Tech
Grand Canyon Tech
