Question about Acer Aspire 3680 Laptop
Possbile battery purchased laptop from canada.purchased adaptor to step up 110volts to 229volts.battery power was low so turned it off.plugged in adaptor and re switched on the laptop.battery started to charge and then reduce in power.
  • slickone Sep 08, 2007
    thanks for the joy without battery.
It could be a battery fault, have you tried it without the battery?
Posted on Sep 07, 2007
Why My Inspiron mini will not start?
It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check hoe the Power LEDs on the system, battery and AC Adaptor react. Then I can check and help you further.
    Thanks and Regards.
    Kiran Kumar.
Jun 22, 2014 | Dell Inspiron Mini 10 Notebook
Hi my presario cq62 battery is not charging can u help me
There are 4 things this could be:
1.) There may be an issue with your outlet/power strip. Try plugging the power cable into a different outlet.
2.) The power cable's brick (that box-like component in the middle of the cable) may have gone bad. Some bricks will have a green LED on them to show when they are operating properly. If the LED is OFF, you need to replace the power cable. If it's ON, the cable is probably OK. If there is no LED, test with a multi-tester.
3.) Your battery may be bad and, therefore, cannot charge. The steps to test this are below (after #4).
4.) You're DC jack (the part inside of your laptop which the power cable plugs into) has broken solder joints due to too much tugging of the power cable over time. The steps to test this are below.
For issues 3 and 4, try the following: 1.) Remove the battery, 2.) Plug the power cable into the laptop, 3.) Try to turn ON your laptop.
If your laptop can power ON, then the power cable and DC jack are working fine and your battery needs replaced. If checking the brick's LED (Issue #2) has proven the power cable is fine, AND the laptop does not power ON, then you need the DC Jack resoldered (PC shop).
I hope this is helpful and best of luck!
Sep 21, 2011 | Compaq Presario CQ62-215DX Laptop
My battery is low and when I plug the power cord into the laptop the light that was on on the adapter turns off and my laptop will not turn on. I have a Dell Inspiron 6400
I'm assuming you are using a GENUINE Dell laptop charger designed for this model?
Check the end of the adaptor, if it is the type that has the centre pin, make sure it has not snapped off.
Check the adaptor is putting out 20 volts DC by connecting a multimeter to the outer and inner parts of the DC jack.
Usually, the ac adaptor LED will flash green if there is no charge going to the laptop ("spitting back power"), however, a dead adaptor is often recognised by a lack of the lED light glowing
You can try with a universal adaptor, it will not charge the battery but at least will eliminate the charger or the charging circuit. If this also fails to power up the laptop, then the issue lies with damage to the motherboard
Jan 21, 2011 | Computers & Internet
My dv7 1245 dx had a short at the ac110 adaptor plug on the 18.5 volt end. This shut my computer down. Twisted wires. I bought a new HP adaptor. The computer will not power up now. The only sigh of life...
Dear Sir/Madam...
You just follow these steps:
1.Remove the battery and Adaptor
2.Press and Hold the On buttun for 30 seconds (without battery/adaptor,this is for reset the BIOS in your Laptop)
3.Now you just connect the adaptor with your laptop
4.On the adaptor socket main switch in main board
5.Watch the Laptop charging Light is ok or not.Also watch the Light in Adaptor is lighting normally or not.if all are normal then try 6th step otherwise problem in your Laptop.Just go for an authorised service center.
6.Try to ON the Laptop
All the Best....
thank you very much By Ganesh(INDIA)
Dec 04, 2010 | HP Pavilion dv7-1245dx Notebook
Gateway laptop model MT6723, when I go to press the prower button the low battery indicater flash about three times also with the power cord plug in with the battery connect please any advise, Thanks In...
Can u use your laptop with battery only? If not then try removing the battery and use the ac power only. If its ok then your battery need to be replaced. If not then i suggest replacing your ac power or both.
Feb 08, 2010 | Computers & Internet
My dell xps M2010 laptop is not working with the battery but it comes on when i plug in the ac adaptor charger. when i checked the bios setting it says battery not recognized and later, when i turned on...
Hello and thank you for using Fixya's services.
Your power adapter is bad and is not able to charge the battery at all (which is why the battery is dead). Yes, this is common with laptops because of the constant plug in and plug out. Yo can purchase a new adapter for less than $25.00 on eBay. Anywhere else it will cost three times more.
Once you replace the adapter, the battery will get a full charge and you will be up and running again.
Please let me know if you have any questions and I will assist.
Oct 27, 2009 | Dell My XPS M2010 Notebook
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
Jun 23, 2009 | Compaq Armada 7400 Notebook
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
Laptop will not turn on.
plug it into the wall , most newer laptops will have a power boost while plugged into AC.
check your power cable receptical on the back of the laptop, these are notorious for getting loose.
check the cable on the ac adaptor, these are bad for getting breaks that you cant see in them (run your hand down the cable physically and fell for any breaks while unplugged, then do it again plugged in and watch for lights to flicker on the computer.
look for the power light on the laptop to come on when you plug the adaptor in. if you get a light on the adaptor and on the computer, then the adaptor isnt the issue.
the next step is checking the power button and power supply.. post what your results are here and we'll move to the next step if not resolved.
Oct 29, 2008 | Gateway Computers & Internet
Acer Aspire 3680 Laptop Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
