Akai PT5499HD replacement TV screen
Hello, I am looking to replace the first layer of the tv that my son has made many tears in. The glass layer below is fine. Please advise if you know where I can find or order this screen, and if possible what the replacement will require (tools/other parts?) Model: PT5499HD 10/2004
  • Anonymous Mar 28, 2008
    broken screen
  • joe elliott May 26, 2008
    also need to buy a new plexiglass screen, where do i get one/
  • 3 Answers
SOURCE: T.V. overheating in our conversion van
the greay line you said is colled a frame collapes this is most likely to be caused by a dry joint on the frame output or in the general aera around the frame chip if you dont have a clue what im talking about seek pro help
Posted on Jan 11, 2007
  • 398 Answers
SOURCE: 51' projection tv(Hitachi 51G500A)
The Hitachi part number for the screen assembly for the 51G500a is KR02844. You can call a Hitachi parts distributor and see for yourself how much those things cost, but I warn you they are not cheap!
Posted on Jun 26, 2007
  • 3 Answers
I contacted they were able to give me a part # for the board that you need. it was around $120. your problem may be more extensive than this though. was there any other service done to the set prior to this happening?
Posted on Oct 15, 2007
SOURCE: Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Posted on Jan 29, 2008
  • 593 Answers
SOURCE: Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Posted on Feb 17, 2008
My Akai pt5499HD has no picture to it and i just replaced the flyback transformer to see if that was the problem. any suggestions?
You need to have copy of service manual for this tv and Samsung PT5499HD service manual will work on your Akai tv as both has same circuit.
Aug 26, 2010 | Samsung HC-R4755W 47" HDTV
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
Can front screen be replaced
all projection screen can be replaced but they cost quite abit of money
Jan 18, 2009 | Akai PTH5498 54" Rear Projection...
hello I am Jaime from Mexico, i have a 54" akai pt5492s don`t turn on, but timer on in red help me please
Sep 16, 2008 | Akai PT5492S 54" Rear Projection...
No power up red light
The symptom you have should be addressed by a qualified -technician. However, the most common cause is either a convergence problem or fluid leaking onto the picture tube socket or the chassis. To check for a convergence problem remove the back of the TV. Typically on Akai the convergence board may be mounted above the chassis. Look for any big aluminum heat sink with a pair of large IC`s (STK-392-040) screwed to it. Mark and unplug the power connector to the board (the red molex connector). Plug the TV in and turn on the set. If the set comes on replace the convergence IC`s and check all the 3.9 ohm (orange,white, and gold stripes) resistors on the board. To check for a fluid leak remove the lower front panel of the set and look for any moisture on or around all three picture tube sockets and the main chassis. If there is moisture, it is necessary to repair or replace the seal, wash the board or chassis and repair any damage from corrosion.
May 11, 2008 | Televison & Video
Akai pt5499hd just shut down
If you are electrically inclined, there is a power deflector board that may need to be replaced. This deals with the high voltage part of the TV, so I am not responsible. The part number we had to but and replace was BP94-01289A or about $130.
Oct 31, 2007 | Televison & Video
PT5499HD Covergence Akai
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Oct 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Check this out USA AKAI CUSTOMER CARE 1-800-726-4405 Hours of operation (Eastern Time): 8:30 am ~ 9:00 pm (Monday through Friday) 9:00 am ~ 5:00 pm (Saturday) CANADA AKAI CUSTOMER CARE 1-800-293-5408 Hours of operation (Pacific Standard Time): 6:00 am ~ 6:00 pm (Monday through Friday Good Luck
Aug 15, 2007 | Akai PTH5498 54" Rear Projection...
Scratches on the screen
if the screen prot. is damaged,replace with plexi glass..avail thru local home improvement suppliers...good luck...john
May 28, 2007 | Akai PT4298HD Rear Projection Television
Televison & Video Logo
263 people viewed this question
Top Televison & Video Experts
