Dunno yet.
I suggest you perform the diagnostic test to see if the problem is the Power On switch, (Located inside the plastic Power On button assembly), or the Power Supply.
(Hopefully your power company wasn't doing any work on your line, or a brownout occurred. Also hope there were no lightning storms present, and the computer was plugged in. Surge protector? With lightning strikes you need a surge protector that costs around $300. The ones that are usually purchased will not provide adequate protection. No matter what they state. {$12 to $60)
The method is to use a jumper wire on the ATX main power cable connector.
The jumper wire connects to the green Soft Power On wire, and ANY black ground wire.
If the computer comes on, (Power Supply actually), you have a bad Power On switch.
A generic replacement Power On switch runs about $5,
http://www.directron.com/atxswitch.htmlIf the computer does NOT come on you have a bad Power Supply.
(Not hard to replace yourself at all)
I would like to start by showing you an illustration and photo of your motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07813&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&lang=en&product=329403&key=nullScroll the page down towards the bottom.
There is a square shape represented in the middle of the illustration, with the bold letter/numbers - Intel 845GL in it, and Memory Controller Hub (MCH) under that.
Below this is the ATX main power connector. (ATX Power Connector)
It is white in color (Photo), and has 20 socket holes.
Two rows of 10 socket holes.
This is a closer look at an average 20-pin ATX main power cable, and it's connector. (Plus the above mentioned connector on the motherboard),
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20The photo to the far Left shows the 20-pin ATX main power connector on the motherboard. (Female connector)
The photo in the Middle shows the Front of the connector, on the power supply's 20-pin ATX main power cable. (Male connector) Plugs into the connector on the motherboard.
The photo to the far right shows the 20-pin ATX main power cable plugged into the motherboard.
(into the 20-pin ATX main power connector on the motherboard)
The photo to the far Right shows the BACK of the connector that you will be using.
The jumper wire is placed down into two socket holes into the Back of the connector.
One end of the jumper wire goes down into the socket hole with the Green wire.
The green wire is the Soft Power On wire. (Abbreviated as PS_ON)
The other end of the jumper wire goes down into a socket hole with ANY Black wire.
ALL Black wires are ground wires.
The jumper wire goes down into the socket hole RIGHT NEXT TO THE EXISTING WIRE that is present.
Goes right beside the wire already in the socket hole.
Every wire going down into that connector ends in a metal terminal.
The metal terminal is pretty far down into the socket hole.
For this reason, you must ensure that the ends of the jumper wire are touching the metal terminals, down in the socket holes.
A paper clip is usually used for the jumper wire. It is nice and thin, conducts electricity, and is stiff.
The paper clip is straightened out, then bent into a U-shape.
The middle of the U is wrapped with a few wraps of black plastic electrical tape.
This area is for your fingers.
Computer laying on it's side on a table, computer case open, computer plugged into power:
The jumper wire is inserted into the two socket holes mentioned above.
IF the computer comes on you have a bad Power On switch.
If it does NOT you have a bad Power Supply.
About the voltage you will be addressing.
1) One wrap of black plastic electrical tape will insulate you from 600 Volts DC.
2) The voltage you will be addressing is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
3) There may be a spark. Cautioning you in advance. You may wish to wear a rubber dishwashing glove on the hand with the jumper wire.
(Sometimes there is no spark. Just cautioning you in advance so you don't freak out)
[Your computer Power Supply converts AC electricity from your home, or business, into DC electricity. (100 Volts AC, 120 Volts AC, or 220 Volts AC. Depends on what country you live in )
DC electricity is what is used by the hardware components inside the computer.
There is 3.3 Volts present, 5 Volts present, and 12 Volts present.
Only if you stick your hands inside an open computer power supply, (and plugged in), would you get shocked ]
For additional questions please post in a Comment.
Regards,
joecoolvette
I can help Anthony just email me cause been searching for you to give u PC parts I had here from dez.
Trying to contact Anthony email me at [email protected] about Dez
