Question about Pioneer NS-DV88 System
HCT 8525 PDA
I've had this phone for a month and condensation has built up underneath the screen. The phone wasn't left outside, didn't get rained on or spilled on. I know I can order a replacement part from FixYa, but i'd like to take the slid/screen apart to make sure it's not a simple fix, like letting it air out or something. I'm looking for instructions on how to take the slide off, and take the screen out. From what I can see it looks like it's only a few screws to get the screen out, but only after the slide is separated. Can anyone help or point me in the right direction? Thanks!
first, you'll have to open the 4 screws at the back,
then open it from the sides with an opener, until the back cover is removed,
then you'll remove the mother board,
then unplug the lcd-cable,
then remove the 4 screws under the mother board, which are holding the upper sliding part,
then remove the screws of the sliding part,
then again, use the opener to open it from the sides,
you'll reach the lcd.
that's it :)
mik
[email protected]
Posted on Aug 26, 2008
SOURCE:
Condensation In Trunk 2001 Buick LeSabre
Is it possible the trunk lid is not aligned right and not applying pressure to the gasket ? Or do you have a crack in the seam where the quarter panel and the center pillar meet up ? Or is it getting in behind the tail lamp ?
Jul 15, 2013 | Cars & Trucks
Rain leaks
NO, it is most likely getting in through the cowl vent area under the wipers. Normally the water drains out the inner fender, but if its clogged with leaves and pine needles, it wont drain and will fill up past the cool air intake and get into the cabin. I would pull the cowl vent grille and make sure the drains are not clogged.
Jun 18, 2013 | Hyundai Cars & Trucks
Unlock code 8525
Unlocking your mobile is very easy.. You didn't mention your network provider and country.. You can get it unlocked by your network provider itself.. Otherwise get the unlock code at Theunlockspot.com for your mobile HTC 8525 by giving the required information...
Nov 27, 2011 | Motorola Cell Phones
I have 2 Samsung AW0700/XAA air conditioners that leak water all over floor. We've tried tipping them to get water out but didn't work. How do we stop leak?
inside the unit on the left side of the evaporator coil there should be a channel that allows the water to drain to the outside of the unit and cool the condenser coil use compressed air to clean this channel (a.k.a. keyboard cleaner) were safty glasses and make sure unit is unplugged then check drain to make sure it is clear before running the unit.
Jul 22, 2011 | Samsung AW1893L Air Conditioner
My jandy pda (pool remote) got wet inside, kids left out in rain and water must have got in behind controls now it does not turn on. What can I do?
Were you ever able to repair it? Our kids recently left our remote outside as well; and am looking for ways to fix it. Thanks!
May 07, 2011 | Sport & Outdoor - Others
Unlock code for 8525 PDA
I need the code for unlock my new att 8526 smartphone, you can help me
Mar 11, 2009 | Cingular Wireless Cingular 8525 Smartphone
White screen on a htc 8525
I have a small solution to what all of you are having with the black screen. I had the same problem so, what you want to do is keep pressing the power button. You do not turn the phone off, you will just put it in standby mode and then back on. If you keep doing that the screen will turn back on but you can not let the back light go out.
Dec 11, 2008 | AT&T 8525 Smartphone
Pioneer NS-DV88 System Logo
122 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
