Problem for Kitchen Ranges
Generic problem for all Kitchen Ranges
Shattered glass top for Hotpoint range/ how...
This top was shattered and we have a replacement, but there are no instructions on how to install this. HELP
Same Problem
Aug 13, 2008
-   We would like instructions on how to replace the cooktop for the JS905
GE model. Thanks!-   Guest Jul 26, 2008
-   have a shattered glasstop, but cannot find a replacement..can you help?-
snayavich
Best Solution
posted on Sep 10, 2007
Rank: Guru
Rating: 96%, 6711 votes
The cook top on your range should come off by removing 2 to 3 screws under the front edge of the cook top. You will need to open the oven door to see them. Once you have them removed the top should lift up. Please ensure you have the range unplugged and/or the circuit breaker turned off before attempting any repairs to the heating elements. Live voltages are still present with the unit turned off.
Now...depending on the type and model of your range, the wiring harness may have a quick disconnect type of plug. If yours is so equipped, replacing the top will be a cinch, because you can remove it from the range to work on it. Take the old top and new top and place them next to each other upside down on a padded surface. Placing some towels on a kitchen table or counter top works best. Now all you have to do is carefully transfer the entire harness and burner elements to the new cook top. You should be able to move the entire assembly with all the burners still connected. A second set of hands will make the process go much easier.
If your range does not have the quick disconnect type of wiring harness have someone hold the cook top up or prop it up with something. Carefully remove the element mounting brackets from the cook top (with all the elements still attached). Carefully support all the wires as you do so, and lay the entire assembly (elements and wires) on top of the oven cavity insulation. Once you have everything disconnected from the cook top, discard the old one and position the new one in place. Carefully reinstall the elements while supporting the wires. Additional care should noted not to handle the ceramic material of the elements and/or the heat coils themselves. They are very fragile and the oil from your hands can potentially damage the elements and shorten the life of them.
Let me know if this helpful to you. If you get stuck along the way, or have any questions, please respond to this posting by adding additional comments.
Was this helpful?3 people thought this was helpful
Popular Solutions for Kitchen Ranges
Questions and Unsolved Problems for Kitchen Ranges
I have a 30 yr old gas Wards MicrowaveRange model CG2500B that has finally given up the ghost. It...
(More)
I have a 30 yr old gas Wards MicrowaveRange model CG2500B that has finally given up the ghost. It was built by Caloric. GE sold a similar unit during that time period. The oven thermostat has died, max temp now is 200 degrees. I'm looking for a thermostat - pn 66363 or Y0066363(Whirlpool says no longer available nor any suitable substitute.) Baring finding a thermostat I need to find a stove with at least the same capabilities and width.
It is a 30" wide with 4 burners on top and the single oven is self clean, convection and microwave all in one. It would cook a 22 lb turkey in about 2 1/2 hrs time. Does any manufacturer currently make a stove with the same capabilities?
I live near Fairbanks Alaska and have a very limited number of dealers here who are all nay sayers. They have never heard of a stove being built this way.
Thanks
am toying the idea of buying a 4 burners and a wok range combined. appreciate some good advice....
(More)
am toying the idea of buying a 4 burners and a wok range combined. appreciate some good advice. thanks.......D.H.
kenmore gas range, oven touchpad and clock are out but stove top works
lower oven won't stay on...gets to temerature and shuts off
GE profile double oven stove how do I use the sef clean
