Question about Panasonic SC-HT920 System
Panasonic SC-HT920 I have only a panasonic sc-ht920 with cord to plug in the outlet and speaker wires to hook up from system to sub but when i plug it in the light will turn on and the music will play out of my normal speakers but the sub wont do anything. how can i get this thing to work?
    Novelist:
    Scholar:
  • 136 Answers
One option is to set the cross over to the sub so it knows when to send the low frequency to the sub and not the front speakers. 120 is a good setting. This can be done either via a know on the sub woofer or the setup screen of the main unit.
good luck
smeags
Posted on Jan 07, 2008
SOURCE:
Sub woofer and rear speakers cut out
Check the speakers with an OHM meter to be sure that they are not bad. Switch the speakers so that the front is the back and see if the issue goes away. If it does not then it is the amp. It could be the temp sensor or overload sensor
Jul 29, 2013 | Panasonic SC-HT920 System
I need a replacement remote because I lost the original in a move.
Hi, you will need to get to a panasonic store or any store around you r area where you can get a replacement remote.
May 21, 2010 | Panasonic SC-HT920 System
Why does the picture flickers,keeps moving down but clear sound
yes this is a simple fix,change the tv channel up 1 or down 1
Aug 05, 2009 | Panasonic SC-HT920 System
How can I connect the subwoofer sb-wa920 to a any audio system
Some systems have a sub out. Does this sub have an output on it? If it does, use it first from your output then out to you other speakers. Hope this helps some but I could really use more information.
Jul 13, 2009 | Panasonic SC-HT920 System
F61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
Feb 22, 2009 | Panasonic Home Theater System System
Sound
Rechecked all wiring found one loose connection
Nov 30, 2008 | Panasonic SC-HT920 System
I lost the power cord to my Panasonic SB-WA920 Subwoofer
partstore.com or panisonicpartstore.com will have any cord you need for a panisonic just have your model # ready
Nov 28, 2008 | Panasonic SC-HT920 System
No DVD picture while playing Panasonic SC-HT920
You should connect your Video cable from DVD to TV's Yellow pin. Then you must first select whether its AV1 or AV2 from remote control. Then you'r done!
Dec 09, 2007 | Audio Players & Recorders
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
Panasonic SC-HT920 System Logo
260 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
