Question about Asko D1796FI Built-in Dishwasher
Detergent lid won't latch shut
Our ASKO D1796 has a detergent compartment lid that is supposed to latch shut and then open during wash cycles. It is normally as simple as putting the detergent in and pushing down firmly on the lid. Now it won't stay shut no matter how hard we push down on the lid. There is a small mechanical arm at the lower side of the compartment that looks as though it is supposed to reset to grab and hood the lid. If I push the arm to reset manually there is an electrical pulsing as though I am pushing against a solenoid. Am I doing something wrong or do I need a new assembly? Thanks!
  • murray5680 Jan 08, 2008
    I have just started experiencing the same problem!! When the power is on, the lid will not shut. Likewise, when you turn the power off, shut the lid, turn the power back on the lid flies open again!! I have removed the front of the washer to inspect it and found the solenoid that opens the lid vibrates strongly when the power is on- almost like there is a relay on the control board switching it off and on really quickly. Thus when you try to close the lid, there is a strong vibration and noise coming from the washer not enabling the lid to close.
    I'm not sure the problem is in the dispenser, as a solenoid from my knowledge will not open and close quickly. They normally either open when energised, or release when de-energised. To create the vibration and pulsing as quickly as it does would need to come from a relay or something I would assume (keep in mind I'm hardly the sharpest tool in the shed, and far under qualified to give advice). There aer 3 relays on the power board though, and one appears to have a blackened look on its clear outer shell. It also warms up consderably when you turn the power on for w ahile with the front cover off- though not half as hot as the poor dispenser solenoid!!
    Please advise though, as like mentioned, I'm far under qualified to offer reliable advice.
    Problem Solver:
  • 14 Answers
The whole dispenser will need to be replaced, they only come complete
Posted on Sep 08, 2007
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
The detergent dispenser lid does not open during the wash cycle for my Kenmore Elite 13783. I tried cleaning the dispenser and using new detergent, but that does not help. The lid opens freely when I push...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Feb 06, 2011 | Kenmore 13783 / 13785 Stainless Steel...
The washing machine doesn't open if I use detergent
read the side of the detergent box it normally says how much, and your washer is probably not opening because it has lid lock to open it you need to pause the cycle and wait a few minutes and it will release the lock also if the washeer is spinning or agitating the lid will automatically lock to open do as described above
Feb 19, 2010 | Asko Washing Machines
Inside detergent compartment door will not open during cycle
to much detergent clean it out and start over
Jan 31, 2009 | Dishwashers
Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Dec 24, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The compartment that holds the detergent doesn't open during the wash cycle.
This could be caused by several things: unit jammed with detergent or other matter, timer issue or even a broken wire. Inspect the latch on the mechanism carefully and, if gummed up, clean it with hot water and a tooth brush. Otherwise, you'll have to get into the wiring and go from there.
Mar 06, 2008 | Dishwashers
Asko D1996 Stainless Steel Detergent Door Does Not Open
the pcb will need replacing,the dispenser gets its power from there.
Feb 28, 2008 | Asko D1776 Stainless Steel Built-in...
Detergent not being washed out of dispenser
This suggestion is not too good. If your dispenser opens at the initial stages of the cycle, just a little - pour some water into the dispenser to wash down the detergent. (For my machine i can pull out the dispenser anytime during the wash, except when water comes into the dispenser, but even then i think the water enters the tub.) For this you dont have to hang around the machine for long for it is in the initial stages of the cycle. Later you hv to check the flow of water into the dispenser. Hv no idea how to do it; but i gave you a quick solution.
Mar 01, 2007 | Asko W6021 Front Load Washer
Asko D1796FI Built-in Dishwasher Logo
478 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
