Question about Philips MX6050D System
Bass speaker stopped working
I think this system is ok for a starter - have some speaker crackling issues, the dvd player shows video, but the audio is delayed (I have a different dvd player to use) - the problem I have with the system is the bass speaker channel has stopped working. The speaker works fine, the channel is not sending power (even with that channel's setting turned all the way up!). Can anyone help me decide what to do with the thing?
SOURCE:
  • 20 Answers
SOURCE: Speakers buzz for about 1 minute when powering on or switching
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Posted on Jul 17, 2008
  • 20 Answers
SOURCE: dvd player works, but no sound from any speakers
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Posted on Jul 26, 2008
  • 141 Answers
SOURCE: No audio is coming through my speakers
If the receiver is actually powering up but you are getting no sound, there are few basic things to check.
Check the audio connections on the back (speakers AND inputs) to make sure they are tight at both ends and undamaged. Go into the setup screen for the DVD player and make sure the audio settings are set for PCM output and that you are using a digital or optical audio cable. Then make sure you have the correct function selected on the receiver to match the inputs. If the receiver has a speaker test function, use it to see if there is any output from the speakers. Finally, make sure the volume is turned up and the mute button is off.
Otherwise, the amplifier may be faulty
Posted on Sep 07, 2008
Nomodo4u
  • 863 Answers
SOURCE: DVD player suddenly stopped working
Turn unit off and unplug, then plug back in and keep finger on eject button, and then hit the power button.  Nothing?  Get your phillips screwdriver and remove the shell.  Then retrieve you disc.  While your in there look for signs of a burned capacitor off the ic port chip and take a little glass cleaner and clean the optical lens with a micro fiber cloth.
Posted on Nov 15, 2009
  • 3 Answers
SOURCE: My HTS3400 DVD Home Theater stopped producing
fechegaray,
if you do a search on HTS3450 (same unit) you will find a thread with similar problems. My problem was similar and today I fixed it by changing 2 capacitors in the unit.
bk
Posted on Nov 30, 2009
Panasonic sa-pt860 speakers crackling
Panasonic SC PT860 Manuals
The above link is the owner's manual - it may help.
Here are some other ideas:
Try to find out if the crackling sound is coming from all speakers or just one - you may just have one bad speaker.
If the crackling happens at high volume settings, you may be overdriving the system - you'll just have to turn it down!
Try turning down the bass or the subwoofer level.
Is the crackling present with all sources (TV, cable, DVD, bluetooth)?
Sep 22, 2016 | Panasonic Audio Players & Recorders
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
DVD problem 2008 xc90 crackles in speakers. Regular stereo does not
Try running a laser cleaning disk in it to clean the laser. Often times it has dust inside and distorts audio and video.
Jan 30, 2018 | Volvo XC90 Cars & Trucks
I installed my eclipse and the only problem im having is when i have the truck key turned forward it sounds good except you cant hear my subs that well and when i start it and turn it up once i get to a...
First off, you need to disconnect your battery immediately.. The reason for the feed back is you have a hot wire touching ground somewhere....probably a large sub speaker cable.....What will happen is the power going from the amp to the speaker or from the head unit to the sub will come into contact with bare metal and feed that current back into the system through the isolated ground. This will either reduce sound, or when the power is high enough, turn from a low hum to a heavy crackle. now if it crackles with the bass, more than likely its in your sub/amp configuration....if its constant or completely random then it could be anywhere in the system. check for bare, broken, or exposed wire.
GOOD LUCK AND PLS RATE THIS POST!!!!
Mar 23, 2011 | Eclipse AVN5500 Car DVD Player
I have a crackling speaker on the left port of the bass box
The crackling sound on the left port of the bass box, indicates vibrating foreign matters inside it. Just open the box and clear it up. Put the sounds on. Listen if the crackling sound is audible. If the result is ok, then, close the box, and everything is alright..
However, if the result is otherwise, then, it is due to a defective speaker that needs to be replaced.
Nov 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
I have a beomaster 2200 and the sound will only come from one speaker, I have checked the speakers and these are ok. When I move the balance control I get a loud crackle noise. Many Thanks John Bailey
if the loud crackle noise is in the speaker that doesnt work you may have a problem with the balance control itself or int. contacts in the switchbank.clean and lube both for starters.
Oct 17, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Surround sound speakers distort when playing blue ray dvd.
what you have to do is turn off your system then turn it on until you get 2 beeps. then go through the on screen instr.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Philips MX6050D System Logo
41 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
