Question about Dell Dimension 5100 (D51L1) PC Desktop
Memory module what is the difference bet.. ddr2 400MHZ, 500MHz and 800MHz and so on..... is compatible in all motherboard.. I have Dell Dimension 5100 with specs: ? Intel 945G ChipSet ? Socket LGA775 Supporting Pentium 4 5XX/6XX Processors 2.8-3.8 GHz ? Hyper-Threading Technology Support ? 800/1066 MHz system bus ? 4 Dual Channel DIMM Support for DDR2 400/533MHz ? 4 GB MAX system memory ? 1 16x PCI-Express Video Slot ? Integrated Intel 950 Graphics Accelerator ? Integrated 10/100 Lan ? Integrated AC97 Sound ? 2 Serial ATA Hard Disk Connectors ? 1 ATA-66/100/133 IDE Hard Disk Connector ? One Floppy Connector ? 2 PCI Card Slots, 1 1X PCI Express ? 5+2 USB 2.0 Ports ? 5.1 Surround Sound Audio Ports Can I Use any ddr2 memory module for my PC? Currently im using 512mb(2x256mb) ddr2 533MHz and i would like to upgrade... thank you very much and more power....cheers
  • benj8 Sep 11, 2007
    i bought 2x1GB can I use also my old 2x256Mb DDR2 together with the 2X1GB memory making it 1536GB? thanks a lot
  • Anonymous Mar 26, 2014
    Is it possible to use 2x2 memory modules in my Dell dimension 9100 with win xp sp3? here are the specs of the modules
    2GB PC2 - 5300 667 MHz DDR2 FB- DIMM memory
    Scholar:
  • 133 Answers
Your motherboard supports 533MHz memory modules, no more. If you put anything higher in, it will work, but only at the speed of 533MHz, so there's not much point in aiming any higher. Just make sure what you're buying is a DDR2 533MHz memory module, and it's best to get them in increments of 2. If you have 4 slots on your motherboard, get another 2x512MB modules of RAM. If you're running Windows Vista, it might be worth considering 2x1GB modules. I think that pretty much covers your question, if you have anything else to ask, feel free to reply.
Posted on Sep 07, 2007
SOURCE:
Have dell dimension 4700 .. tower Led's A,B are yellow and C,D are green... a series of beeps when start... 1 long 3 short 2 short .. screen in power save mode.. have cleaned out dust in fans and inside...
This is a sign of a memory failure. You will need to open the case and remove all of the memory.
Remember to ground yourself before starting. To open the case, disconnect all external cables (including the power cord), then lay the machine on it's side with the cover up. Slide and hold the latch on the back, if there is one, then grip the cover at the indents and slide the cover towards the back of the computer.
The memory sticks are held to the motherboard by clips on the ends of stick that need to be pushed away from the stick.
Then reinsert one memory stick. The modules will only fit the slots one way. There is a notch that lines up with the motherboard slot. If it doesn't line up, turn the memory around (pins of cross face into the motherboard). When the memory module is fully seated, the clips should automatically pop to lock into the notches on the ends of the memory stick. Then turn on the computer. If it boots normally, shut down and add another memory stick then restart again. If it gives the error again and you have multiple memory modules, take out the first one and try a different memory stick. (Similarly as you add memory, any stick that causes a problem should be removed until you have tested all of them and only the good memory modules are still in the computer.)
If the machine is under warranty, contact Dell for replacement memory modules. Otherwise, replace them with compatible memory if you want to maintain that amount of memory in the computer (most manufacturer's have a tool to look up the correct memory for a given machine). Memory is sold at most of the computer stores and repair shops, online computer stores as well as directly by some manufacturers. The memory needs to be 400 MHz or 533 MHz unbuffered, non-ECC DDR2 SDRAM (however, Dell often uses propriety RAM so again check the compatibility).
I hope this helps.
Nov 03, 2010 | Computers & Internet
Will 2 Sticks Of This Memory Work In My Foxconn Mobo?
Check your memory that is in your computer. I believe it uses DDR and not DDR2. It should say on your old memory. They are not compatible.
Jul 20, 2010 | Computers & Internet
My Dell Dimension 9150 is unstable. The Dell Diagnostic indicates memory failure in DIMM socket 3. I reversed the modules in the DIMM sockets and Dimm socket 3 failed again. Motherboard?? My motherboard...
Yes you can. Your best is to use the largest and best ram in the number one slot. I would remove ALL the ram and start with the 2 gig in the first slot - then add others until you get the error message - remove that one and keep the rest.
Mar 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I bought a pentium 4 3.0 ghz 800 mhz & my
The motherboard chipset of the Dell Dimension 2300 Desktop PC, will not support a processor with an 800MHz Front Side Bus frequency rate.
Only Intel Pentium 4's that use a Socket 478, 1.75 Volts, and a maximum of a 400MHz FSB.
The Intel Pentium 4 HT 3.0GHz processor has an 800MHz FSB, (As you have already stated), and uses 1.475 to 1.55 Volts.
The motherboard chipset for that Dell Dimension 2300, is an Intel 845GL.
This list on Wikipedia, shows you parameters the Intel 845GL chipset supports,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Not a good outcome, sorry. Just stating the facts.
Jan 08, 2010 | Dell Dimension 2300 PC Desktop
My dell power light was off one morn,but my
Seems to be a Memory or a Motherboard failure. Make sure the memory you upgraded are the ones which are compatible to the system.
The compatible memory modules for your system are:
DIMM, 128MB, DDR2, 400M, 16X64, 8, 240pins
DIMM, 256MB, DDR2, 400M, 32X64, 8, 240pins
DIMM, 512MB, DDR2, 400M, 64X64, 8, 240pins
DIMM, 1G, DDR2, 400M, 128X64, 8, 240pins
The power light not turning on can be the Front bezel issue and not a system/motherboard failure. Please revert for any more issues.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
RAM
You may have bad or incompatible Ram . Verify that the memory you have is compatible. .
Machine name: Dell Dimension 3000
CPU options: Intel Pentium 4 or Intel Celeron
Chipset: Intel 865GV Chipset
HD Bus: Ultra ATA/100
Front Side Bus options: 800MHz FSB
Memory Speed options: PC3200 DDR400 184pin SDRAM DIMM
Special notes: The Dimension 3000 has two different bus speeds each of which takes different memory. You cannot mix the speeds.
Take the memory out and install one at a time. This way you can verify that the memory is indeed working. If you find a bad one, replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2009 | Dell Dimension 3000 PC Desktop
Will 2 different memory modules work together on dimension 2400??
it will work, but not optimal for a good performance. Always choose memories with same ratings for best results
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
I get "virtual memory low" message and cannot boot.
The real solution to this is going to involve spending some money to buy some new memory. It should cost about $30-50 depending on type and amount. 256Mb is not enough for Windows and other software to run. I would recommend buying at least 512Mb additional to add. Before you purchase open up your machine and look to see how many memory slots you have and how many are currently used. According to some specs on the internet, here is what you have.
Maximum Memory 2GB Memory Slots 2 (1 bank of 2) Install in pairs non-removable base memory 0MB Machine name: Dell Dimension 3000
Special notes: The Dimension 3000 has two different bus speeds each of which takes different memory. You cannot mix the speeds. Please check the speed on the memory modules currently installed, or use our "Check Your Computer" to find the correct module.
It is simple enough most anyone can do this themselves, and I could walk you thru it, otherwise you would need to take it somewhere, but my recommendation would be to do it yourself and simply ask me or others here for advice. Let me know if you want help to do this.
Good Luck!
b
Dec 13, 2008 | Dell Dimension 3000 PC Desktop
PNY memory
Hi
Dell Dimension 5150 supports DDR2 400MHz (PC2-3200) and DDR2 533MHz (PC2-4300) unbuffered SDRAM Memory (DIMM). You may install a total of four DIMMs in capacities of 256MB, 512MB, or 1GB. The maximum memory supported is 4GB.
From your query, I think the obvious question is; What is specification of the PNY DIMM and/or does the PNY DIMM meet the requirements for Dimension 5150?
Check for memory configuration and installation procedures for Dimension 5150 - http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
The Chipset used on Dimension 5150 is Intel 945G Express. I am not aware of specific compatibility issues regarding the Intel 945G and PNY Memory modules. However, there may really be known issues that I am not aware of.
To proceed, ensure that the PNY Memory is compatible with Dimension 5150. If not, install compatible (memory type, speed, capacity) DIMMs.
Let me know if further help is needed.
Mike
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Promise SATA300 TX2 Plus PCI controller card compatibility
Southbridge shouldn't matter as that is the controller for audio.
As the supported intel chipset is listed there should be no conflicts.
Apr 12, 2008 | Computers & Internet
Dell Dimension 5100 (D51L1) PC Desktop Logo
145 people viewed this question
Ekse
Clive
Clive
