Question about LG LS-L1210CL Mini Split Air Conditioner
The fan in the outside part of my AC doesn't run
When I open my LG, the fan in the outside part of my AC doesn't run. The inside part provides some air for few minutes and then my breaker overloaded and turned off. Is is the fan on the outside part that is the problem???....What can I do to resolved it?
  • natmelodia Sep 08, 2007
    I tried to put my unit on FAN ONLY, and the power stays on!.....That means my problem is my compressor right??? ( sorry, my English is not very good, so it's hard for me to understand difficult words. My first language is french)...
    That's great to hear that some manufacturers offer three years warranty! Because it's been only 2 years that we bought this A/C with the constructor of this condo, so I'm gonna try to ask the constructor for the warranty!...
    If it is the compressor the problem, can we change the compressor or do we have to change the whole unit?
If it is the compressor at fault it will be at the discretion of the manufacturer as to what they replace. I would suggest you contact an aircon engineer who can help you diagnose the problem because a professional will have to be in touch with the manufacturer. As you are getting in touch with the contractor who supplied the equipment that will be the correct route to go. Hope this helps.
Posted on Sep 09, 2007
  • 87 Answers
On most air cons there is a time delay before the outside unit starts and LG are no exception. This function means that erratic power supplies wont kill the compressor (outside bit). If the internal fan runs for a few minutes and then the trip goes then it sounds like you have a faulty compressor. This tends to be a scenario for a failed compresssor. What you can try is putting the unit on FAN ONLY (no cooling) and see if the power stays on. If you are more technically competent you could isolate the power to the compressor on the external unit (AFTER ISOLATING THE POWER TO THE WHOLE SYSTEM). And then try putting it on cooling to see if the external fan works. If the trip is not thrown then you have a faulty compressor. I would also like to point out that most A/C manufacturers offer a three year parts warranty so you may have some sort of cover depending on the age of your unit. In which case get an aircon guy out who knows what they are doing (personal reccomendation is always a good starting point). Hope this helps.
Posted on Sep 07, 2007
  • MARK FISHER Sep 09, 2007
How may capacitors are there in LG split ac 1.5 ton unit
At least 3. 1 on the inside unit fan, 1 on the outside unit fan and 1 on the compressor. The outside unit may have both in a single chassis.
Aug 15, 2016 | LG Electronic Window Air Conditioner
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
I have Carrier 38TKB036 3 ton A/C condensing unit and one 28CCA036 3 ton A-coil to provide A/C to home thru existing furnice. A/C was on and stopped working. Turned off/on, but will not come on. Any...
Is the furnace fan (indoor fan ) running. If not the problem is with the inside unit. It supplies the control power to operate the entire system and has a control fuse on the circuit board. If it is running but not the outside unit then the problem is outside.
Aug 08, 2011 | Carrier 38CKC042 Air Conditioner
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
LG split AC LST243H-2 not working at all,failed while on
i want purchase a split ac 1.5 ton our temperature may month 45 to 46 C which brand Ac purchse
Dec 29, 2009 | LG Heating & Cooling
Inside fan running outside not
There is an electrical box on the wall near the outdoor unit. open it and be sure that the circuit breaker is in the on position. Same in your electrical panel, be sure that the circuit breaker is turned on.
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Nordyne AC unit works at first but later provided cool air. Thermostat set to 65. Power running to unit outside. Noticed ice around line outside and can send a picture. Chipped ice away. Want to know what...
If the inside fan motor is running OK you are low on refrigerant. If the inside fan motor is not running, repair the inside fan motor. Could also possibly be dirty inside coils.
Jul 20, 2009 | Heating & Cooling
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
203 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
