Question about Denon AVR-2106 Receiver
Hooking up dvd, tape, karoke machine to denon reciever
I'm trying to set up my denon receiver with the other technologies i own. I've connected all video cables, audio in and out to the receiver. I connected the tv to the tv space on the receiver; the karaoke machine to the cd slots on the receiver; the tape player to the dat/mon slot; and the dvd machine to the dvd slot on the receiver. I get nothing show up though when I press the buttons on the remote control and tell the reciever to go and play the dvd machine....? Help! i have Denon AVR-3200
  • 979 Answers
What happens when you select options from the front of the reciever?....accordianman
Posted on Oct 25, 2007
SOURCE:
Denon DP300F no audio output to harman kardon 158 reciever
A turntable can NOT be connected direct via a tape input on any amp. Magnetic Cartridges require a special socket often called a "phono" input. If your receiver doesn't have a dedicated socket, by the sound of it doesn't, then you need to get a magnetic cartridge pre-amp. The turntable will plug into this and that will plug into the tape input on your receiver.
Jun 02, 2013 | Audio Players & Recorders
I just purchased a Sony flat screen tv and need advice on what wires I need to connect my Denon AVR-3300 to it or to the dish cable box? My remote has these options on the remote to listen in...
Your reciever has three digital optical inputs so, what it comes down to is how many thing do you want to hook up and what input/otput do you have on your TV. Best case scenario would be to hook your cable box directly to your TV Via HDMI out, if you have HD, on your cable box to Sat/cable input on your TV. Next best would be using componenet cables for video and digital optical for audio. Last would be RCA(yellow, white and red, from Cable box to TV input. Then, you would connect your TV to receiver via(best) digital optical, or RCA. You can try to patch the video through the reciever using component or RCA to TV/DBS on receiver then out to TV but. alot of times you will lose the video in the transfer and it uses more cables, thus more margiin for error. You would set your TV menu to cable/sat and your reciever to which ever input you choose.
Jul 03, 2011 | Denon Audio Players & Recorders
Trying to connect HP M9060N and Sharp Aquos through Denon AVR 1508, only get 'no signal' response. Have HDMI 1 set to DVD, HDMI 2 to AUX, HDMI 3 to TV, which is order of HDMI outlets on receiver.
Depending on your TV inputs, you are better off to run video componenets through TV first then, connect TV to reciever via digital optical. Recievers have video pass through but, noyt the best route. You can use TV's menu to choose what you watch and, only have the one output from TV to reciever. Make sure you scan through TV and reciever menus to make sure you are selecting the right channel.
Jun 21, 2011 | Denon AVR-4306 Receiver
Denon AVR 1609 7.1 Channel Receiver turns on but i get no sound thru the optical to the tv. what could be wrong?
If you have your video equiptment hooked to your reciever input, then, out to TV, This isn't the best way to go. Of course it depends on what you have for input and output on your TV but, the ideal way to hook your system would be to hook all video equiptment to TV, ie:, cable/sat box, DVD player, etc., to TV via, HDMI, Composite, RCA, etc., then run your digital optical out from TV to reciever. You would use the TV's menu to choose what you watch and would only have one input(audio) to reciever. Some recievers are set up to transfer video, but, it uses more cables, creates more connections, and more room for error.
Jun 13, 2011 | Denon Audio Players & Recorders
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
Is it possible to connect my panasonic sg-hm22 to my Denon Reciev
You need an "Audio Output" ie. Tape 2 mon or Rec out (RCA jack) on the Panasonic for it to work. Hope this helps
Jun 22, 2009 | Panasonic Audio Players & Recorders
Sound with HDMI but no video
the Denon does not pass 1080p change the output res from the DVD/PS3 or Xbox to 720p or 1080i will solve the problem
Nov 18, 2008 | Denon AVR-2807 Receiver
Denon Avr-1803- multiple room audio difficulties!
it is true pre amp check your cables and confirm in (avr-1100)that you select the right input.
May 27, 2008 | Denon AVR-1803 Receiver
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Dec 31, 2006 | Denon AVR-2801 Receiver
Denon AVR-2106 Receiver Logo
310 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
