Something you may want to try is start from the beginning. Check to make
sure there are no other bluetooth devices loaded onto your phone that
might interfere with the process. Turn off your phone. Disconnecting the
battery of your mobile for 30 seconds and reconnecting helps to reset
the phone. The instructions for turning off the headset and re-pairing
the two devices are located in the following link for the Plantronics
Discovery 925 User's Guide.
You want to make sure that there is no other bluetooth interference
on your phone and follow the instructions on the link for the
Plantronics Discovery 925 (see page 4).
Yes, there is a way to adjust the volume on your Discovery 925 headset.
See page iv to locate volume control button and page 8 for the
instructions in this link for the Plantronics Discovery 925 User's Guide.
Once you make your LG Lotus discoverable, then put the Plantronics
Discovery 925 into pairing mode by holding the call control button until
the headset flashes red and blue. Here is the link below for the
Discovery 925 pairing instructions.
Sounds like you have a bum unit. Plantronics gives a 1 year warranty with every wireless product, I'd send it back.
Have you made sure that you're turning it on correctly? You push the call answer button and hold it down for about 3 - 5 seconds before it turns on, until the blue light turns on. Make sure that you don't hold it longer than that or it will go into pairing mode.
i jus need the owner manual for plantronic discovery 925, the dint send me the manual,i have bunch the bluetooths but a want to try this,if you can help me send me 1 copy is ok if not is ok to , i not gonig to $39.00 dolr for the manual, idont want tecnical suport like a say i just need the owner manusl, thanks,ifo you want to charge $39.00dlrs for the manual i prefer buy new plantronic 925 for anohter $10.00 dlrs ,thank any way
The round portion that has the smaller hole in the center, with the small extension, goes into your ear. The squarish loop then needs to be rotated to out, so that it is "hooked" into the curve of your ear. Try different sizes to get the right fit of the loop (the bodies are identical).
I've had the same problem where no one is able to hear me. I finally discovered by looking at the opening where the mic is that it was plugged up with debris. I took a soft brush (toothbrush) and cleaned the debris from the opening and and like magic it cleared it up. Everyone said I sounded fine and clear. Make sure the opening is clear of any debris and remember not to put the narrow part of the headset where the mic is located inside your ear canal. Use a cotton swab to clean your ear (lol)
I hope this helps
