Question about Alpine CDA-7995 CD Player
Cd player problems
So today on my way to school and i was wanting to listen to a cd, so i pushed the eject button and i tried to put the cd in and it wouldn't go in, so i pushed the eject button and it took it, but heres the problem the cd only went in a little bit to where it would have just a little bit sticking out and it starting spinning. I tried to get it a little push to go in but it won't go. So i took the cd out and i pushed the eject button to close the deck and it didn't move. So i had to use my hand to move it. I don't know what coukd be wrong. Please if any help could be given i would so appreciate it.
I installed a dual xdm7510 reciver in my car and it worked fine for a day but now it will not play anything. Sometimes it will play and sometimes it will just eject any cd that I put in it. write me at [email protected]
Posted on Jan 04, 2008
SOURCE:
My 5 disc CD changer will not eject an hung CD , on an Infiniti 2005 G35,..any solutons???
Some CD players actually have a locking mechanism inside of them. This mechanism can be released by using an unwound paperclip and sticking it into the CD player. There should be a button or platform to push that could release the disk. If that doesn't work, you might want to try using a pair of tweezers to pull the disc. To do this put the tweezers inside the CD tray and try to pull the disc out while pressing down and holding the eject button on the CD player. To me, it sounds like the motor that sucks in and ejects the disc is slowly dying and is having trouble pushing the disc out. If all else fails you might want to take the car to a dealership to see if they can replace your CD player
Oct 19, 2012 | Cars & Trucks
My 05 g35c 6 disc cd player don't work. Screen show push eject but when I push eject, nothing happens. Can any one tell me what I can do.
verify that the cd holder is in correctly, being put in incorrectly would probably cause a jam not letting it read or eject, also see if when you push the button, listen really close, and hear if it makes a noise, like little motors or solenoids buzzing or whirring, that will tell you if the thing even still works
Sep 17, 2010 | Car Audio & Video
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
The CD player/changer in my car is not loading or ejecting the CD's. When I push the load or eject button, it makes a grinding sound. It was playing fine yesterday but since I left a CD inside the CD...
I just acquired the same problem. I tried to put a new CD in and it wouldn't take it. I ended up pushing it in when I was trying to get it back out and now it won't play the CD, or eject it. I think it could be stuck between tracks, but they want $188 to look at it and fix it even if it is a simple fix. I am looking for suggestions also, Diane
Mar 13, 2010 | 2003 Mazda Mazda6
Cd jammed in player
MY DAUGHTER PUT A CD IN THE CD PAYER AND NOW MY CD PLAYER DOES NOT WORK.I HAVE A 2005 NISSAN ALTIMA.THE KIND OF RADIO IS A BOSE 6 CD CHANGER.I PRESS THE CD BUTTON AND IT SAYS PUSH EJECT.I PUSH EJECT AND IT SOUND LIKE IT'S TRYING TO EJECT BUT NOTHING COMES OUT.CAN YOU HLP ME
Jun 13, 2009 | 2005 Nissan Altima
'99 Mercurary Tracer cassette player problems...
The cassette adapters are notorious for getting stuck in the deck. More often than not its the wire that comes out of it that causes it. The cleanest and safest way to remove the cassette adapter is to remove the radio, take off the top and "Help" it eject with your fingers or some narrow tool that may get behind it to push it forward and out. If you dont want to take the deck out of the dash, you can try pushing the eject button while manipulating the adapter wire, but I dont recommend it. Its just better to take the deck out. Good Luck
Feb 06, 2009 | Car Audio & Video
Cd wont eject
You are absolutely right about bose! And GM Delco as well. Try this. I've had 50/50 results. Need 2 peole. One at the nattery, the other at the cd player. Turn the key on, radio will power up. with the radi powered up,disconnect the negative battery cable from veicle. Wait a few minutes. Now this step might be cumbersome. While holding stereo in your hand, push the eject button and HOLD while the other person re-connects the negative power cable back up. Ths will do a reset on the stereo and you may get lucky!
Don't put anymore cd' in it. Your only other option if you want that CD bad enough is to disassemble the case of the stereo and manually move the mechanism to eject it. Hope this helps
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Car Audio & Video
CD won't eject....
you need cleaning and maintenance on your radio if you want to eject the disk theres a little tiny button on the face you will need a pin push it in and this should eject your disk
Sep 27, 2007 | Kenwood KDC-215S CD Player
Cd ejection
Look for a tiny, recessed Reset button on the front of the unit with the face removed. Press this button with a pen tip; it should spit out the CD and work correctly afterwards. This will also erase your station presets and audio settings.
Mar 13, 2007 | JVC KD-SX770 CD Player
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Alpine CDA-7995 CD Player Logo
181 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
