Question about Linksys Wireless-G WGA54G 802.11g/b (wap54ag) Wireless Gaming Adapter
Error in detecting the game adapter
When we click setup it continiously says that it is unable to find the game adapter after we have checked all of the cables and made sure that they are plugged in right. It won't do a thing after it gets to that message and says to check the cords. We have spent about 2 hours on trying to get it to work
    Sergeant:
  • 274 Answers
What's your OS? XP or MAC, what??? Tell me more about what system you are using. Then someone can help you.
Posted on Sep 09, 2007
SOURCE:
1670: unable to load module d:iss setup.dll,error code:193
this game was not released for the PS3 and may not be compatible with the newer hardware.
Jun 22, 2013 | Activision Spiderman: Friend or Foe for...
1670: unable to load module d:\iss setup.dll,error code:193
get current PS update when you turn on system - if the update doesn't automatically load - go to system - system updates - follow instructions on machine.
Error code 51420
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
May 05, 2012 | Nintendo Video Game Consoles & Games
Trying to connect to internet on my wii console but it comes up with error code 51420
error code 51420 means The Wii console is not able to connect to your wired router or modem.
Try to do this step hope it will help you plzz rate me tnxx...
Jun 04, 2011 | Nintendo Wii Console
I have direct tv and I am trying to hook my wii up so I can watch netflix it is giving me an error 51420
Error Code: 51420
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51420&system=Wii&locale=en_US
Apr 01, 2011 | Nintendo Wii Console
I am trying to hook my wii to the internet and it is saying unable to connect error code 51420 and i need free advice or help.
For any help click here
Jan 04, 2011 | Nintendo Video Game Consoles & Games
Error 211
When getting error 211, you will need to manually install the drivers for the adapter.
Exit from the error message, then remove the CD and restart your computer.
Plug linksys usb adapter, the computer will detect the adapter.
Right-click on My computer then click properties, go to Hardware > Device Manager.
Under Other Devices, you will see 802.11 g WLAN with an exclamation point. Right-click on it and select Update drivers.
Then insert the CD. (If the installation setup screen appears, just exit it.)
Then on the update driver screen, click browse and select your CD-ROM drive.
Then click finish.
If you are using Win 7, follow the steps from this link.
If you cannot open the link, just go to kb.linksys.com. In the search bar type 20873. Answer title: Error 211 - Installing Driver Manually for network adapters to work in Win7.
I hope this helps!
Apr 29, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
Error code 51420-- wii is hooked via usb to modem and unable to connect
This is directly from the Nintendo Tech Support Site
  1. If your connection worked previously, check to see if thereis a Wii System Update that you have not aquired. To get the latest WiiSystem Update:
  3. Check to make sure you are not running the Wii LAN Adapterfrom a USB hub (a device that connects multiple USB products through asingle device), as this will likely not work. Connect the USB Connectordirectly to the modem or router.
  6. Ifpossible, try another Wii LAN Adapter. If you are unable to try anotherWii LAN Adapter, or are still receiving this error code, please call1-800-255-3700 for assistance.
If you need step by step instructions on how to set up the Wii LAN, click this link
Installing the Wii LAN Adapter
Dec 08, 2009 | Nintendo Wii Console
Linksys Wireless-G WGA54G 802.11g/b (wap54ag) Wireless Gaming Adapter Logo
89 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
