Question about Sharp SF 2020 Copier
Sharp sf-2020 4?'s please
1. I need a product manual for my newly gotten old copier. I've searched everywhere and can't find one. 2. I am having difficulties getting the paper catch tray (for the fresh printed copies) to catch the copies properly. It seems to be a bit too high for the exit area. 3. How do I remove the small purple piece at the back of my paper drawer in order to set it to 11x17 paper? 4. As well I would like to know how to set it so that it will keep multiple sets of copies in order instead of putting all of page one next to page one and two next to two. Thank you so much
  • 4 Answers
I have a product manual of different kinds of sharp photo copier machine just email me at [email protected]
Posted on Jul 02, 2008
  • 163 Answers
Pleaz check it in internet by loging www.sharp copiers.com
Posted on Sep 13, 2007
You will be able to download the manual from this address:
http://www.nodevice.com/manual/newmans/sf2020pdf/get10209.html
Posted on Apr 24, 2008
SOURCE:
Sharp AL-2020 - Copier Producing Copies with Faint portions at Top Middle and Bottom of Page
This if often a faulty toner issue. If you are refilling it might be time for a replacement carrier. Alternatively have you checked your transfer belt for areas of damage
Jun 30, 2014 | Sharp SF 2020 Copier
I have sharp sf-2025 keys number from 1 to 9 wont work.. pls help..
Hallow , keys are like electronic switches which wear with time may be due to dirt inside or normal expiry. They need to cleaned or replaced with similar ones. Open the control panel and unscrew the keyboard. You will identify them by their indication with a ' k' for example key 6 is written 6k. You can use WD-40 solvent cleaner if it doesn't work, then use a solder iron to remove old ones and buy sample like on any electronic shop and replace. Happy new year.
Dec 30, 2010 | Sharp SF 2020 Copier
I have a Sharp SF-2030 copier & I would like to disable sorter
Uninstall the sorter unit then you should go to simulation mode by entering these buttons :
C interrupt 0 interrupt ( less than 5 seconds ) 26 start 1 start then change the value to 0 and start
Good luck
Mar 11, 2009 | Sharp SF 2020 Copier
Melted exit rollers SF 2020 Sharp copier
Please.....do yourself a favor, and call a service tech.
Feb 27, 2009 | Sharp SF 2020 Copier
On a sharp SF-2020.. I get a U5 code with 01 subcode...
u5 indicates the ADF can't communicate, make sure the ADF is pluged into the copier. MAKE SURE TO UNPLUG COPIER BEFORE CKECKING ADF PLUG. If all is good then main board is bad.
Feb 25, 2009 | Sharp SF 2020 Copier
Sharp SF 2020, how to clear F code
GO ON LINE AND TYPE THE FOLLOWING:
SHARP SF2020 COPIER ERROR F CODE
ENTER
OR
WWW.SHARP.COM/COPIERS
ROD
Feb 10, 2009 | Sharp SF 2020 Copier
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Sharp AR 5316e copier
check if the developer that comes in a silver bag has been installed and the screw that fastens the scanner has been removed.
Jun 19, 2008 | Sharp SF 2020 Copier
146 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
