Question about Panasonic KX-P2130 Matrix Printer
NOT PRINTING OUT OF DOS PROGRAM
PRINTS OUT OF WINDOWS,BUT WHEN TRYING TO PRINT OUT OF DOS LOTUS PROGRAM TYPE,DOES'T PRINT AND LOCKS UP,UP GRADED TO A UBS PORT TO A PARALLEL. HAVE XP. HAVE A DYNEX CONVER TER CABLE,
    Master:
    Sergeant:
  • 461 Answers
Check the print setting for DOS version. make sure driver is properly install. Not from window selected drive. i.e. using the provided drive from manufacturer.
Posted on Sep 09, 2007
    Sergeant:
  • 279 Answers
The problem is, the DOS program tries to print to LPT1, which is your parallel port. We need to redirect this to your USB Port. First, you have to set up printer sharing: Go to Control Panel | Printers | Your printer and share the printer. Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type go to Start | Run and type in: NET USE LPT1: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES That should do the trick, unless there's a driver problem, which is unlikely for a dot matrix printer. If that doesn't work, let me know and I can troubleshoot further.
SOURCE:
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Printer full of ink, but will pring pages either blank of with smeared ink.
Follow these steps to check the print settings for your print job.
  1. In the software program you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Select your product, and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing shortcuts tab.
  4. Under Printing shortcuts , click the type of job you are trying to print.
  5. Review the following options, and then make any necessary changes.
    • Paper size : Make sure that the selected option matches your paper size.
    • Paper type : If one of the options matches your paper type exactly, select that option.
    • Print quality : If you are not satisfied with your printed page quality, or want more densely printed prints, increase the print quality. To print more quickly, or for lighter prints, decrease the print quality.
  6. Click the Features tab.
  7. Check the Print in Grayscale setting
    • If you are trying to print in color, select Color Options , and then make sure that Print in Grayscale is not selected.
    • If you are printing a black and white image, select Print in Grayscale to fix streaking in black areas.
  8. Click OK , and then click OK again to start the print job.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center , then click Settings , then Printer Toolbox .
Select the Services tab.
Click Print PQ (print quality) Diagnostic Page .
Select the Services tab, then click A- Click Align Printheads or
B- Click Clean Printheads .
C- Click Calibrate Linefeed .
If, after repeated printhead cleaning, the Print Quality Diagnostic page shows white lines across the color blocks in Test Pattern 2 (but no white lines in the gray blocks in Test Pattern 3), one or both of the printheads will have to be replaced. The Print Quality Diagnostic page shows which printhead should be replaced.
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
Nov 16, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Extra Line when printing from a dos-based program
your printer paper size shorter than your PC dos-program print size setting, example: if use a letter size paper to print a A4 size file which should occur two paper go out..
so you need check your PC print setting or take a presetting paper size, make a size match between PC program and paper in printer .
hope you fix it, please take a rating let me know how much helped you thanks!
May 21, 2009 | Dell 5100cn Laser Printer
Printing from 1989 DOS program "Labels Unlimited" with same
sound like a parallel connection.
Try this:
open a dos command prompt and type this command:
dir>lpt1
this would try to print through the dos mode if you connections is good it should print something.
Mar 26, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Print from DOS
Try Start --> Programs --> MS DOS
or Start --> Run --> enter CMD
this will take you to a DOS screen
To print a file use the type command and pipe it to LPT1
e.g. type myfile.log > lpt1
Feb 16, 2009 | Compaq Inkjet Ij300 Printer
How to redirect lpt print to canon lbp-3000 printer
Here's what you need to do. ON the computer that you want to associate that LPT1 port, you need to know the name of the computer, and the share name of the printer. In this case, I am assuming you have the Canon LBP-3000 physically connected to this system running the FoxPro program.
Step one: Find the computer name. Click on START SETTINGS CONTROL PANEL. Double click SYSTEM. Click on the tab COMPUTER NAME and under FULL COMPUTER NAME, write down the name. Click OK to exit the window.
Step two: Click on START, SETTINGS CONTROL PANEL. Double click PRINTERS AND FAXES. Right click on the Canon LBP-3000 printer and click on SHARE. In the window that opens, click on SHARE THIS PRINTER and take note of the name in SHARE NAME: and write it down. Click on OK to share the printer and exit out of the wizard.
Step three: Click on START, RUN. Type CMD in the box and click OK. in the black window, type NET USE LPT1 \\COMPUTER NAME\SHARE NAME
Follow with RETURN or ENTER and you should be good.
Aug 04, 2008 | Canon LASER SHOT LBP-3000 Printer
Doesn't print correctly
Current printers do not have a 'built-in' font or character set. The printers only print what they are told to print by the application from which they are printing. What program are you printing from? Does it do this with all programs? Check printing from very basic programs like Notepad or Wordpad (print documents that are at least a couple of pages long). If the printer prints correctly from there, you may need to contact the publisher of the program that is giving you the weird printing.
Apr 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lotus 1-2-3 release 3.4 Printing Problems
you tried another worksheet and that doesn't print?
you tried another DOS program and that will print?
Apr 08, 2008 | Computers & Internet
Panasonic KX-P2130 Matrix Printer Logo
977 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
