Question about Pioneer VSX-D608 Receiver
DVD MALFUNCTION The DVD player is diplaying a NO NUM message on the display window, initialy, which then turns to REGION. On the TV screen the following message is displayed: (Player's Region Setting), followed by <1>: Region up to <6>: Region, then at bottom of message written Pick out any one of these! The problem is that you can't pick any region as they are not clickable and all the buttons of the remote don't work except for volume control and 'System Setup'. When DVD holder is opened then the 'Home Menu' button works with limited functions. Therefore, due to this all DVDs can't play excepting those with automatic start.
  • 319 Answers
DVDs and CDs are formated with regional encoding 1-6. If your player does not support the format, it will not play the disk. You might try looking up your brand/model player online to see if it has a regional patch code which you can enter via remocon.
Posted on Aug 14, 2008
How to make my Samsung HT-BD8200 region free?
1. Open the disc tray and remove any discs
2. Close the disc tray
3. Switch Off Player and Unplug from mains wait minimum 30 seconds - this resets the memory, and RAM of the DVD/BlueRay
4. Make sure your TV is on as usual, and Reconnect to mains
5. Turn on your DVD/Blueray player with remote and wait for the "no disc" message to appear
6. PS! As quickly as possible, using your controller press - ENTER 8 4 2 6 9 ENTER
7. You have been successful when a blue box appears in the top left-hand side of the TV Screen, displaying the message "DVD Region Free"
You may have to attempt the "ENTER 8 4 2 6 9 ENTER" sequence several times before you get the Region Free message if you're not quick enough.
May 08, 2011 | Samsung HT-BD8200 Theater System
Region unlock code for Pioneer DV-220KV-k
hey. the manual has its region codes. we have the same problem. my dvd player says re61 and i don't know how to key in the code... i tried to press the 4 number codes but doesn't work. arrgh. makes me wanna throw it!
Jan 30, 2010 | Televison & Video
When i put in a dvd i get a message wrong region,is there a fix for this problem
You should be able to unlock all regions on your standalone DVD player using a series of keys on the remote this will unlock it to region 0
1. Switch on the DVD and open the tray.
2. From remote . Press four times zero : 0000 + (the digit for corresponding region , e.g 1 for region 1 , 2 for region 2 and similarly ----- 0 for region free
(This means if you want region free settings then u need to press 00000 or for region 1 : 00001)
3. Message will be displayed on screen saying region 0 which means the DVD is region free !!
You can check the region by open the tray and pressing the display button on the remote
I suggest you try THIS is the above doesn't work
Jan 04, 2010 | Philips DVD634 DVD Player
Region code unlocking pioneer dv-220kv
My DV-220KV-K, which is sold as a Multi Region DVD player has locked up on me. The following message comes onto the TV screen...
(Player's Region Setting) <1> : Region <2> : Region <3> : Region <4> : Region <5> : Region <6> : Region Pick out any one of these!
The message remains on the screen ALL the time and I'm locked out of viewing anything. The remote is locked and so I cannot pick any of the region numbers!
Dec 08, 2009 | Pioneer DV-220V-K DVD Player
PHILIPS DVD player 616K, how to change region or get into right region. my player was working OK. Suddenly it stopped functioning and showed/diplayed '' wrong region'' on the TV screen.
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', '0' in that order
if that dont work go 1, 1 1, 1 in that
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
note: you want to chose region 0 so u can use all regions
Nov 15, 2009 | Computers & Internet
Can i make it region free?
Turn on your DVD Player
Press OPEN on remote
Press 1 3 7 9 and the number of the region you want to use between 0 and 6. Use 0 for region free. You may need to press these buttons slowly. You will see XXXX on the TV. When you press the last number, it will display at the top left of the screen.
Now insert a disc (other than your own region) into the player and close it. It should load and play. Other region discs should play as well. If you didn't do it correctly it will display "Wrong Region".
When you turn off the DVD player it will keep the settings.
Oct 11, 2009 | Daewoo DVG-9100N
Regional code
4.- PRESS ENTER UNTIL SHOW "Region code: 9" (Region Free)
1-Turn on your DVD player.
2-Open the tray.
3-Press 9 five times, you will see a number (for me it was 6, you'll see it on the screen, where the DVD displays all messages, like a blue bar up top) then I pressed 9 a few more time until the number being displayed there turned to a 9, when it does then press enter, now it's region free.
Mar 10, 2008 | GPX D2816 DVD Player
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
Sep 08, 2007 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
PL-D2000 DVD Home theater System
Comments: To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region Ensure TV monitor is on so and set to display DVD. 1. Turn system completely off. 2. Turn on system. 3. Open tray. 4. Using remote press and hold the return button. 5. While holding the RETURN button, press and hold the DISPLAY button. 6. You will see something like this displayed on screen: VER 1006 TE 3210 7. Release DISPLAY and RETURN buttons simultaneously. 8. Press the ANGLE button. You will see WRITING REGION ID displayed. You can now play DVDs from any region. 0
May 27, 2007 | Teac PLD2000 System
Pioneer VSX-D608 Receiver Logo
132 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
