Watches Logo
A
Anonymous Posted on Aug 21, 2013
Burberry silicon band replacement - Burberry Watches
Timex T5K143 Ironman. How do I get a replacement band for the watch please?
Question edited for clarity.
Replacement Watch Bands & Straps
Timex https://www.timex.ca > browse > replacement-straps
Replacement 18mm Resin Strap for Ironman® Essential 10 Full-Size. C$ 15.99. Strap Only StrapOnly. Replacement 20mm Bracelet for Highland Street Gray large.
  • Replacement 20mm Resin Strap for IRONMAN Classic 30 ...
    https://www.timex.ca > Replacement-20mm-Resin-Stra...
    Replacement 12mm Resin Strap for Ironman Essential 10 Mid-Size. C$15.99 ... I had to have a jeweler mill down some of the plastic so the band would fit.
    "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 42px;"> Rating: 3.1 · ‎8 reviews
Timex Ironman Watch Bands Replacement
Amazon.com https://www.amazon.com > timex-ironman-watch-ban...
5pcs Compatible with Timex Ironman Classic 30 Watch,Ironman Essential 10 Mid-Size Watch Replacement Silicone Band Holder Loops with a Tool to Remove The ...
Replacement Straps for TIMEX IRONMAN Watches
Timex https://www.timex.com > browse > ironman-replaceme...
Replacement 15mm Silicone Strap for Ironman Essential 30 Gray large ... Replacement 18mm Resin Strap Watch for Ironman 100 Lap Modular Black large.
Total Watch Repair https://www.totalwatchrepair.com > collections > timex...
Total Watch Repair sells Timex Ironman Watch Bands and Replacement Straps online. ... Timex Ironman Indiglo Triathlon Shock Black 18mm Rubber Watch Band.
Timex Resin Wristwatch Bands for sale
eBay https://www.ebay.ca > ... > Wristwatch Bands
44 Results ; 14mm Timex Ironman 30 Lap Navy Blue Ladies Replacement Watch Band TX754261T. C $20.28. C $48.76 shipping ; 15mm Timex Ironman Triathlon Blk/Orange ...
1helpful
Point zero manual
pull crown out to second position then press start button till it goes to 12.00 then push crown back in ....job done......
1helpful
Replacement band
Contact MK for the band the replacement is not available aftermarket. It is a common problem with the silicone bands.
I need a replacement band
Try www.strapcode.com. You'll need to know the width of the band in millimeters, but you should have plenty of replacement choices.
2answers
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 • Watches
Top Burberry Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Burberry Watch Expert? Answer questions, earn points and help others
