posted by commando on Sep 07, 2007
Looking for a place to buy the wire to connect the monitor speaker to my PC.
Comment by commando, posted on Sep 28, 2007
The problem continues...Here is the error I am getting:
0xC00D11BA: Cannot play the file
Windows Media Player cannot play the file because there is a problem with your sound device, such as a sound card or sound controller. You may encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem, see the Sound Troubleshooter in Windows Help or refer to your sound device's documentation.
You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again.
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Are there drivers required???
1 Other User Has The Same Problem
Comment by xanxeni, posted on May 18, 2008
0xC00D11BA: Cannot play the file Windows Media Player cannot play the file because there is a problem with your sound device, such as a sound card or sound controller. You may encounter this error message for one of the following reasons:
- Your sound device is in use by another program. Quit other programs that may be using your sound device, and then try to play the file again.
- Your sound device is not functioning properly. To troubleshoot the problem, see the Sound Troubleshooter in Windows Help or refer to your sound device's documentation.
- You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again.
Best Solution
posted on Sep 07, 2007
You'll be looking for a 3.5mm Stereo cable. They usually come with green or black jacks on the cable. Where monitor speakers to computer connections are concerned, you'll need the "male to male" version of the cable.
Here's an example:
http://www.cablestogo.com/product.asp?ca...
Here's an example:
Comment by Orbixx, posted on Sep 28, 2007
The cable doesn't, however your computer's sound drivers are not installed. Your PC manufacturer's website will have these available for download in their support section.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Fuji FujiPlus FP-7688B / 17" / 12ms /
Email this problem
Email this problem
Can you Help with these Monitors problems?
Repair Service
Find Monitor Repairman Near You:
