Question about Motorola Mobility RAZR V3
FREEZING PHONE MY PHONE FREEZE TIME AN AGAIN AND SOMEONE TOLD ME THAT I SHOULD FORMAT IT,MAYBE IT WILL GET BETTER SO I DONT KNOW WERE TO START.
  • Anonymous Feb 18, 2008
    freezing phone
    Brigadier General:
  • 7,752 Answers
Take the phone and have it reflash that should corect the issue you are having.
Posted on Feb 18, 2008
SOURCE:
Can I cook filet of beef then freeze for a meal a few weeks later
They can be frozen after cooking but will be better frozen until wanted.
Aug 23, 2017 | Refrigerators
LG cookie screen freezes randomly
maybe your phone is overloaded with files. try to remove your memory card first. if the problem persist, you might consider flashing your phone. visit here for more information. you need this first Multiloader 5.56 and Samsung New PC Studio 1.1.2.ID3
more info on http://darkforestgroup.com
Jan 22, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Freezing
ugh same probleme but i cant even txt like everytime i shut it off again it just keeps doing the same thing. BUT untill you take it in to a store to get fixed use abc and DONT push the #(space) button....cause thats what frezzes it. right now i just use dots for spaces lol.. apparently You need to get your phone formatted and software reinstalled thats what someone told me. so just bring it in to a store
Jun 22, 2009 | LG VENUS Cellular Phone
Hi my name is Ernest my computer freezes when setting up xp. I first format the drive and it copies files into the computer and reboot to fish the installation but, it freezes at boot up, it freezes in the...
first you need to partition the drive, then format it, for XP use NTFS file system.... by the way.. if someone already set it up for you..why are you doing it again? Its supposed to be a one-time thing
May 22, 2009 | MSI PT880 Neo FSR Motherboard
My new ipod pink nano 8gb keeps freezing
First you have a bad port on computer you probably need to plug your cable in the back of the computer. If you keep letting your ipod freeze like that your going to seriously mess it up. I'm going to teach you a way to fix your problem with freezing. the next time your ipod freezes hold the "MENU" and "CENTER" button at the same time. After that you need to take your ipod and restore it through iTunes. Please rate this response I would like to know if I helped.
Apr 13, 2009 | Global Baby Once Upon A Dream Musical...
1988 Volvo 740 cold condition, started short, cannot start again
Check the fuel pump fuse and fuel pump relay first, before replacing the fuel pump. The fuses and relays are behind the the ash tray, The fuses are labelled. The relay is on the left side of the relay rack, closest to the big round bulb out sensor. But before that, how about pouring some gas line anti-freeze or fuel injector cleaner into the tank?
Dec 23, 2008 | 1988 Volvo 740
My lg kt520 just keeps stalling/freezing and turning off,i was told i need to doould be ok bot dont know how my lg kt520 just keeps stalling/freezing and turning off,
it looks like the phone needs resetting, in reseting the phone, you may loose data, so better if you have them backed up first.
restart the phone, from the standby screen type in:
2945#*# and select option 6 (reset) from the menu.
The phone will restart and after about a minute you'll be working again. Make a note of the code, because you'll be needing it every few months.
hope this helps
Aug 06, 2008 | Cell Phones
My 700 gets stuck with the last map
Same problems, you have to update as far as I know and you have to update every year otherwise it will start to freeze up. It's a rip off because it's $99 a year. Does anyone know if the other GPS companies do this?
May 14, 2008 | Magellan RoadMate 700 GPS Receiver
My Sharp 903 SH freezes soon after I switch it on
Sharp 903SH freezes\soon after switch on'
the best thing to do is reprogram the unit' but if you dont have special gadgets and software there is two way to solved the problem.
1. Is the hard resset' or format'
by pressng power botton and key (#) at the same time'
the phone screen turn to white' and release the power botton and key #' you can see the phone is in format mode
there 3 stage to be wait while formatting it
wait until the phone say press any key to continnue.
after pressing any key the phone will reboot'
after re-boot the phone screen is blank
but don't panic' just remove batt. and insert it again and power on the unit. thats it
take note: the phone battery have atleast 4bars...:D
the 2nd is mannual resset'
turn on the phone go to menu select settings,
select master reset or masclear,
you can see a massage' just press always YES.,
and enter the code..
The zCODE is 9999...
wait until it finished and turn it off the phone....
thanks for rating this trick solution...:D
Mar 31, 2008 | Sharp 903 SH Cellular Phone
SLIVR L7 FREEZING/NO SIGNAL
mine is freezing up..all the time,,fix it pz..
Feb 22, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility RAZR V3 Logo
15 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
